Oil leaking out on yardman mower
You haven't supplied a lot of information but generally when this happens it is due t the mower being tipped the wrong way.
If you must look under the mower then tip it back with the handles to the ground and front wheel in the air.
Now to rectify your problem; The air-filter will probably be saturated with oil. It will probably be the cartridge type which is not serviceable. Purchase a new filter (take your old filter so the sale person can compare like for like). Before you refit the new filter, take out the sparkplug, it will probably be saturated in oil - wash it in petrol, let it dry then refit it. The engine should start and belch out great quantities of smoke. Don't be alarmed this will burn away. Once the smoke has cleared, check the oil level, fit the air filter and mow your lawn.
