Question about Toys
I have a super x ped with a 2 bolt G260 i just bought a 30.5 cc big bore kit new crank and it wont start. Put a new ignition and new sparkplugs it doesn't start.
    Brigadier General:
  • 8,619 Answers
Hi
If you have just put the k&n air filter on then because with the filter, it removes the choke which makes it harder to start with the pull starter, Try removing & resetting the carb & manifold gaskets. Make sure to us some Locktite on the screws. Also check your hp carb settings and make sure they are exactly the instructions say, make them perfect. High speed 1 full turn out, Low Speed 1 & 1/2 turns out, idle screw all the way in. You can download full instructions here:
Super X Ped Instructions Manual
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
Pulsar 150 CC 2008 Model -I forgot to change engine oil for 10 mnths & nw the mechanic say engine got ceased and bore and piston kit has to be changed. How much it cost for both piston kit and bore ?
Hi, Muth* I recommend a big bore kit for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.xbhp.com/talkies/help-me/13496-pulsar-150-rebore-new-kit-180cc.html
Converting Pulsar 150 to 180
CYLINDER KIT PULSAR180 CC ZADON
Bajaj Pulsar 180 DTSi Workshop Manual
Bajaj Pulsar 150 DTS User Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 21, 2016 | 2007 Bajaj Pulsar 150
How to install a big bor kit on a 50 cc scotter
It's a pretty big job. You need to be competent (and confident) with tools as well as diagnosing and repairing gas engines. Without knowing the details of your scooter, the overview is this: 1) Remove the carburetor (if mounted to the cylinder), exhaust pipe, cylinder head, cylinder and piston. 2) Have the cylinder bored out** to provide the correct clearance between the cylinder and the piston (if different from the scooter manufacturer's clearance this information should be provided by kit manufacturer). 3) Modify the head (more machine work to reshape the combustion chamber to work with the larger bore). 3) Reassemble. 4) Modify the fuel system (usually a carburetor) to correctly fuel the now larger displacement engine. 5) Get the new set up running and then tune it to run properly without damaging itself from an incorrect fuel mixture.
** Some cylinders are aluminum with a steel sleeve that forms the bore that piston runs in. Some are aluminum with a thin nikasil coating on the aluminum bore. These will be much more expensive to bore out as they will need to have the coating replaced after being bored out.
Mar 19, 2013 | Small Engine Carb Repair Tool: Mini-bike...
I want to modify my ghost 50 with malossi kits or airsal cylinder an power converter an exsoss
All engines are tunable! There is an 80cc big bore kit available here
http://www.scooteradvertiser.co.uk/en/for-sale/DAFIER/index.htm
Just don't expect neck wrenching acceleration and 5 mile wheelies. Good luck. And keep it rubber side down.
Aug 22, 2012 | 2010 Dafier Ghost 50
Can i put a big bore kit on a yamaha xt 125x 10 plate,and where would i be able to purchase one from?
Hi, Wallywheelan the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Big Bore An XT 125 With TTR125 150cc Bore Kit
Big bore 150 cc Barrel and piston kit suitable for Yamaha XT 125 2005 2011...
http://gigi600.altervista.org/immagini/xt125r/XT%20125%202005_service.pdf
OEM parts for Yamaha
YAMAHA XTZ 125K Owner Manual
Jun 27, 2011 | Yamaha XT 125 X Motorcycles
I HAVE JUST BOUGHT A '92 MODEL XT600 AND i WANT TO PUT THE BIGGEST "BIG BORE KIT " IN IT WHAT SIZE CAN IT TAKE? AND WHERE CAN i PURCHASE ONE FOR BEST PRICE?
Stock bore is 95 mm, Wiseco offers a 101 mm piston, some crankcase cleanup is required. Will be 672 cc monster when you're done. Actually am building one right now for a supermoto screamer. Good luck!
Jun 11, 2011 | 1990 Yamaha XT 600 E
I have a cpi sx 50 cc with a big bore kit 80cc i put a new spark plug in and it fires up no problem and rides ok then after about five min riding the bike cuts out and wont start again until it cools down...
sounds like an ignition problem namely the coil or module. you might check to see if these are warm to the touch or hot after riding your 5 min. if so a meter check will determine if replacement is necessary. also check for loose leads anywhere. also make sure your plug is good and the right heat range for the bike. i assume you are saying it quits running but doesnt lock up. if its seizing up then your rebuild kit is likely the culprit and will have to tear it down and check clearances with the rings and cylinders and piston etc. good luck.
Jun 01, 2010 | 2007 Highland Supermotard
I bought a 2002 yamaha blaster rebuilt top end. New wisco piston and only bored cycl. 20 over. started up second kick. rode great about 3 hrs then parkes it. It ran great. I put 93 gas with yamalube in mix...
Try a new spark plug. Go to a motorsports dealer to purchase a new one as alot of discount or big name store can get a lower grade of sparkplug and this can create alot of grief.
Feb 02, 2010 | 2003 Yamaha TT-R 125 LE
What size jet would i need if ive got a 70cc big bore kit on a standard carb ??
I believe the standard starting place is to go 2 jet sizes bigger, but I would check with the manufacturer of the big bore kit to make sure. Hope this helps
Oct 26, 2009 | 2000 Yamaha XV 125 - S
Carb tune up gilera runner 50
on the carb you will find 2 screw one will be quite far in than the over thats the one you adjust this is the mixture screw which controlles the air and petrol together unscrew it say 1/4 a turns at a time and see if it improves if it gets worse screw it the oposite way and see if that improves good luck buddy
Aug 10, 2009 | 2005 Gilera Runner VX 125
2002 Low rider Starter seems to be making noise it never did before, It also seem to start the bike with a loud pop when first used. I have 45,000 miles and I did the 103 big bore kit 3-4 months ago. The...
did you get the high torqe starter installed when you put the big boar kit on.the factory starter doesnt like the big boar kits.if you did you may have broken teeth on starter or starter ring
Aug 02, 2009 | 2002 Harley Davidson FXD Dyna Super Glide
Toys Logo
48 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
