Question about Dell 1815dn All-In-One Laser Printer
Fuser door open printer not working what is
Fuser door open printer not working what is fuser door
    Problem Solver:
  • 12 Answers
Back of the printer -
Posted on Jun 22, 2009
Fuser door open?
Try fuser door should be in the back. If it is close, it could be a door sensor issue. Also make sure that the fuser is in correctly.
Jul 07, 2015 | Samsung ML-3051ND Laser Printer
How do I clear a "door open" message when no doors are open and I have checked the door sensors?
re install the printer drivers or
reset the printer by eject the power and data cable for a one minite
Nov 26, 2014 | Samsung CLX-3175FW Multifunction Laser...
Reinstall software. You do not have to
uninstall the original software, re instalation will roll over it.
Brad
How do you remove fuser
->Turn off the printer and remove the power cord. Allow the printer to cool off for 30 minutes to an hour before attempting to work with the fuser. The fuser gets very hot while the printer is in use, and you can be burned if you touch it before it cools.
->Press the release lever on the side door to open it. Pull down the fuser lever so you have room to grab any jammed paper.
->Pull the jammed paper out of the fuser unit. Hold the paper at its lowest point and pull downward. Flip the fuser lever back up and close the side door.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Office Equipment & Supplies
What is "fuser door open"
Fuser Door Open is the message on the display when it's powered on. I took the back apart, removed the fuser, looked all over. I couldn't see any kind of sensor, optical or mechanical that makes when the door is closed. There's an access plate with a blue latch below the fuser that makes an optical sensor and a mechanical sensor, but that seemed to be OK. It didn't seem like something that would be called a fuser door. So, I pushed on it where it made the mechanical switch and the printer hummed to life and the message went away. I took the fuser out and examined it. The metal brackets where the pivot parts were, seemed a little bent. I straightened them out, stuck it back in and that fixed it.
By moe who hasDell MFP 1850DN this might also help...
or Fuser Door Open
1. Make Sure the Paper Tray is Loaded Correctly With no Obstructions
2. Clear the Paper Jam in Tray 1 or 2
3. Clear the Paper Jam in the Multi-purpose Tray
Jul 05, 2011 | Dell 1815dn All-In-One Laser Printer
The fuser door is stating it is open when it is closed I have turned off and taken out fuser turned on and then replaced. still showing fuser door is open will not print or copy
That is a problem with the fuser door switch which is a part of the High voltage power supply. Replacing the HVPS should fix this right up.
Apr 28, 2011 | Dell 1815dn All-In-One Laser Printer
Ricoh aficio sp 3200sf fuser door open error getting "fuser door open" message. opened and reclosed fuser door to make sure fuser door was closed. restarted printer. still get same message. what can i do...
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Jun 16, 2010 | Ricoh Multifunctional SP 3200SF...
Fuser door open on dell 1815n
If you have tried closing the fuser door (rear door) several times and the error continues. You most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Oct 02, 2009 | Dell 1815dn All-In-One Laser Printer
Reads open heat error
This sounds like a problem with the fuser or possibly the fuser lamp. You can try turning the printer off for about ten minutes to cool the machine off and then turn back on. If that doesn't work you would need a new fuser unit. The fuser is located behind the door on right side of the machine. There are four screws used to hold the fuser in place. Good Luck, I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Fuser replacement
Wow i've worked on old printers but this is the the cream.
1-Open back door and remove the back cover ( two screws)
2-remove the top cover.
3- remove the cleaning pad cover and the pad,
4-take out two screws that hold fuser,
5-unplug fuser (two plugs, power and sensor plug)
6-remove fuser
Aug 07, 2008 | Lexmark Optra S 1855 Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
1,799 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
