Question about Lands Phones
Well it said format so i pressed yes.then i
Well it said format so i pressed yes.then i checked my music it was all gone.how do i get it back
    Problem Solver:
  • 6 Answers
I'm sorry but once you format anything, all is lost.
Posted on Jun 20, 2009
Had to format pics and when i pressed ok all the pics are gone
If you formatted the disc then YES your pics are gone.
Jan 26, 2013 | Cameras
Hi there, I just dropped my nokia e63. The moment it fell down its battery just came out. I think it fell on snow and the water may have gone inside it. After re-assembling my phone I just opened my Music...
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Dec 31, 2010 | Nokia E63 Cell Phone
Please help, i have lost a lot of pictures from my camera and i have a horrible feeling i pressed the format button without realising what id done. Are all my pictures lost?
Unfortunately, if you formatted the card, yes they are gone. The memory is flash memory, and reformatting erases all information on the card. You might try taking the card out and downloading to your your computer, but it sounds like they won't be there. Always be careful, once you format a card there is no turning back.
Feb 22, 2010 | Canon Cameras
My 5220 music player dont work and calculator is gone
press *#7370#
to format ur phone... by providing nokia default security code: 12345 or
u can reinstall software via nokia software updater using internet,,,, hope ur problem will be gone,,,,
Jan 14, 2010 | Nokia 5220 XpressMusic Cellular Phone
Sony NWZ-B105f shuffle repeats same songs after start up, does not pick new songs.
Press and hold the Reset button for 30 seconds then try playing the songs. If the issue persists then format the walkman then reload all the musics and try playing back.
If the issue persists even after performing all the above mentioned steps then service is required.
Follow the under mentioned steps to format the Walkman:
Press and hold the Back/Home button in the Pause mode until the Home menu appears.
Press the up/down/left/right button to select Settings, and then press the >|| button to confirm.
Press the up/down/left/right button to select "Common Settings," and then press the >|| button to confirm.
The list of "Common Settings" options appears.
Press the up/down/left/right button to select "Format" and then press the >|| button to confirm.
"All data including songs will be deleted. Proceed?" message will appear.
Press the up/down button to select "Yes," and then press the >|| button to confirm.
"All data will be deleted. Proceed?" message will appear.
While the memory is being formatted, an animated display appears. When initialization finishes, "Memory formatted." message appears.
Aug 24, 2009 | Sony NWZ-B105FWHI / NWZ-B105FBLK MP3...
How to put music on a lg scoop
hi,
Start by formatting the MicroSD card
1. Insert a microSD card into the phone.
2. Press OK to enter the Main Menu.
3. Within Settings/Tools select Memory then press OK.
4. Press 3 to select Card Memory.
5. Press the Right Soft Key under Format.
6. Press the OK key for Yes.
To Transfer Music
7. Connect the USB cable between the phone and your PC.
8. Press OK to select Transfer Music.
9. Press OK again to confirm disabling voice calls.
10. On the computer, drag and drop music files into the drive.
Apr 09, 2009 | Microsoft Office Professional 2007 Full...
No sounds n95 nokia
try format your phone, you must back up your file first, copy all important data as contacts, images, musics, then remove your memory card from your phone.
soft format = press *#7370#
it'll ask if you want to do a -factory setting?- press yes
then try your headset and remove it again, if problem occurs, try hard format
hard format = when your handphone is switched off , press simultaneously (at the same time), # button, 3 button, green call button, and lastly press on-off switch for a long time, it'll blink few times and format itself, your data will be erased all (instead of just factory set), it'll look like brand new the first time you buy it, no data at all. then try if the problem still occur.
Last solution if after format still have that problem, you need to upgrade it via Nokia website. Use your cable, your PC suite, and upgrade it via Nokia website. Remember to have your battery full during this all process or your phone will die.. and you have to spend extra money to bring it to technician later..
Nov 14, 2008 | Nokia N95 Cellular Phone
Problems uploading music
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
Oct 01, 2008 | SanDisk Sansa m240 MP3 Player
Flash error
Generally this either means you have a filesystem error or the flash memory that your mp3 player stores its music on has gone bad.
If you plug the mp3 player into your PC and view its drive letter in my computer. By right clicking to open the command window you can choose format. When you make sure you do not have quick format checked, go ahead with the format. This will erase all of the music currently on it, but may fix the problem with replacing the file system. If your memory is bad, your best bet is to replace the unit. Repairing these is generally never worth the cost since they drop in price half every 6 months.
Jul 28, 2008 | iLO (2 GB) MP3 Player
Sansa e250
reload the firmware from Sandisk's website, if they strill carry it - i heard rumors they discontinued it
Jul 15, 2008 | SanDisk Sansa e250 MP3 Player
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
