Question about Dacor DMT2420SS Microwave Oven
How to fix a decor carousel that doesn't turn?
Carousel runs sometimes. mostly turns 1-2 times and then clicks?
  • saboliving Jun 22, 2009
    thanks you. hard to replace? I think it's about a $35 part.
    Sergeant:
  • 212 Answers
Turn table motor going out
Posted on Jun 20, 2009
  • kenrick driscoll Jun 22, 2009
    need to uninstall unit. take bottom off off unit. that will expose motor
Turn table revolves very slowly
make this test and fix it. God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Nov 01, 2013 | GE XL1800 1100 Watts Microwave Oven
Mcc1010t magic chef micro/convection
follow this steps and fix it. God bless you
Jul 13, 2013 | Microwave Ovens
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
My Oster microwave (model #OGG21401) doesn't heat. When operating the light will turn on and the carousel will turn but food will not get hot. Can you provide a solution to my problem? Thank you.
Check the door safety interlock switches for proper operation. #1 trouble with microwaves that operate in all respects but no heat.
Thanks for your question @ FixYa.com
Sep 16, 2011 | Oster 0.7 Cu. Ft. Compact Microwave
Carousel does not turn
This is quite a common problem and often associated with a recent spill (boiling over) of liquid in the microwave. Liquid overflows the glass dish, onto the floor of the microwave and down the hole where the drive motor that turns the plate is located. Liquid runs down the shaft of the motor and into the drive motor which then stops it functioning. Because the drive motors on most microwaves are induction motors, and not driven by a traditional armature with brushes, about 75% of the time you can fix this by drying the motor out (Though this depends on the liquid spilled).
You will have to get into the underside of the microwave, often this means snipping a bit of the casing directly under the drive motor (Which is of course directly beneath the drive shaft that pokes up beneath the glass plate).
Once you gain access, you will see the motor clearly and it is usually held in place by 2, 3 or 4 screws, unscrew from mountings, unplug the power wires (They usually have a couple of wires from the motor with a little plug on the end that you can pull out).
Give the motor a good shake to remove any liquid and then go put it on top of your boiler, in your airing cupboard, out in the warm sun or even (If you trust yourself not to cook it!) in your oven on a very very low heat. Leave in the warm place for a day (not that long with the oven option!!) until it is thoroughly dry. To test, plug it back in, but don't bother to reassemble yet. Turn on the microwave and see if the spindle turns. If it does, it's fixed, if it doesn
Jul 22, 2011 | Maytag MMV4203D 1100 Watts Microwave Oven
How to fix an Emerson microwave 8992RD that carousel doesn't turn and doesn't heat your food..
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 08, 2011 | Emerson Black Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
My in-laws just gave me a Panasonic Genius 1250 watt microwave, because they said that the carpousel ran all the time. I thought that I would see if was something simple. What I found without looking...
im wondering if your trying to kill yourself? inside this microwave is a very big capasitor,, it works like a big spung holding lots of volts in it, it can also work just like a police stun gun if you tuch it, but it may not just stun you, it could just as easy kill you insted so going inside this microwave is to say the least dangers, but its your life,
Mar 20, 2010 | Microwave Ovens
Microwave oven carousel won't turn
This may be a bad carousel motor problem. If it is, this is an easy problem to fix and rather inexpensive. Please provide me with the make and model number of the your microwave and I will attempt to locate a part number and price for you. I can also provide you will step by step instructions on how to repair. I hope this encouraging for you. Please post back with your information.
Jan 17, 2008 | Microwave Ovens
Dacor DMT2420SS Microwave Oven Logo
104 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
