Question about Car Audio & Video
VZ Commodore Radio Antenae Replacement
I have a new radio antenae mast to replace the the broken one how do I do it please
  • 20 Answers
Its screws off the bottom where it connects to your vehicle, just grab a wrench and take the old one off and put the new one on the same way. if you are replacing the whole wiring to the radio then you'll have to have alot of time because you'll have to feed the new wire through the frame of the car, just fallow the old wire
Posted on Jun 23, 2009
Where is radio antenae connected?
To the antenna itself. If you remove the antenna and pull it out you will see where it is connected.
Jan 20, 2013 | 1999 Ford Windstar
I bought a new antanea 3 ft fiberglass with mirror mount when hooked to radio needle swings all the way to the red and i dont transmit or receive but when hooked back to old antenae works fine old antenae...
Mirror mounts need alot of Ground to tune correctly. Most mirrors don't ground to the door good enough, not to mention the reflection of the radio signal off the cab. Be sure it's grounded good and the nylon insulator is place.
Jan 14, 2011 | Cobra 29 LTD CB Radio
Loss of Signal
Please make sure the antenna is tuned to proper SWR.
Also double check the power wire connections.
Let me know if you have no clue about tuning the SWR.
May 26, 2010 | Cobra 19 DX IV CB Radio
Radio and cd player only play out of left dash speaker. It seems to me that equalizer works ok,(only one speaker to check it with) but when I fade over to right side channel, nothing. The antenae is hooked...
I had this same problem. After reading other ideas and some trial and error, I finally got it. Most Caravans have an Infinity system (the speaker grill will say Infinity on it) ,which uses an amplifier to run the door and rear speakers. I had to ground the clip wire that was originally attatched to the strap ground on the factory installed radio. Then I also had to hook the wire on the new radio for power antenae (blue and white on my unit) to a blue wire on my new harness. This wire came from the last wire of 7 wire harness that had the other 6 wires for speakers. The original wire appeared to be green/red on my vehicle. After I connected both, the speakers cameon and sound great again.
Apr 26, 2010 | 1997 Dodge Caravan
My sirius satellite radio stopped working antenae not found
my sirius satellite radio stopped working the screen states antenae not found in the car and at home on the boom box the antenae has been checked and is not the problem can this be fixed ?
Jan 29, 2010 | Sirius Satellite Radio Audio Players &...
Fitting new antena aerial to Saab 93
Len-
The replacement only costs about $20. The dealer can also provide a replacement but it can cost upwards of $50+. Part number is 5035944.
The hardest part is removing the metal sleeve from the mast pole. Once you get this out, refit the new mast with the teeth so the motor will pull the new mast down when you turn the radio off. refit the 17mm nut on top of the mast and then turn the radio back on. It will click a few times and then be properly set.
Justin
Strictly Saab
Melbourne, FL
Jul 07, 2008 | 2000 Saab 9-3 Viggen
Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Apr 03, 2008 | Car Audio & Video
Car Audio & Video Logo
277 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
