Toshiba SD-3950 DVD Player Logo
A
Anonymous Posted on Apr 26, 2014
How do i hook up my dvd play - Toshiba SD-3950 DVD Player
4answers
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
1helpful
How do you get dvd player to play? put dvd in and
there is a wire comming off the back of the radio that should be wired to an emergency brake put the emergency brake on and play movie or remove wire from emergency brake and just hook it to a good ground basically all it is is a ground wire that when the ebrake is not engaged it does not make a connection to keep you from using the tv while you are driving because it is ilegal to have the tv playing while ur driving all you need to do to bypass it is find the wire and just ground it to a solid ground if you had an install shop install the radio by law they have to hook it up properly or you can ask them to leave it and you can hook it up they can not hook it up so that the player plays all the time hope it helped
2answers
We have a Panasonic DVD-S35 wont play color
We have a Panasonic DVD-S35 wont play color UK dvd's, US dvd's are ok any idea what's wrong?
Can't see dvd on TV
how to hook up to watch dvds
2answers
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
1helpful
3answers
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Hooking mini dvd camera to play through the television
tape needs to be played from camcorder only w/ a/v cables to tv-no other way unless you make dvd on computer first
Dvd player
Are you trying to watch the dvd while your driving? Depending on who hooked up the radio the DVD receiver is only supposed to come on when the emergency brake is engaged. You may have to hook it up another way for it to play while your riding.
Wont play
Try resetting the unit by pressing the small, recessed button on the faceplate with the tip of a pen. If this doesn't work, the player may be defective. There is no wiring error (including failure to hook up the parking brake input) that will prevent the unit from playing CDs.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
