Question about KitchenAid KSSC48FMS Side by Side Refrigerator
What temperature should the refrigerator&freezer be set to?
The unit shut off and we are not sure how to reset it.
Snowmaster BD60DE keeps on beeping while doors are shut
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Mar 26, 2016 | Kenmore Refrigerators
H 1 Flashing
This is actually stating "HI", as in either the refrigerator or freezer, temperatures are Hi and not at a safe level. First, press any button to stop the alarm and clear the HI temperature. If you are still receiving the alarm, I suggest checking the freezer, to make sure that everything is still frozen, and nothing is defrosting as, well as checking the refrigerator temperatures. If things are defrosting or the temperature is Hi in your refrigerator, I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, Give your freezer 24 hours to stabilize at the default temperatures of 0 degrees for the freezer and 37 degrees for the refrigerator.
Mar 24, 2015 | Frigidaire Refrigerators
Freezer on side by side is not working properly
Good Morning Friend,
I understand the freezer portion is not working properly on your Frigidaire refrigerator, model# GLRS234ZA. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire GLRS234ZA Side by Side...
The freezer works but the refridgerator does not work
I understand the refrigerator portion is not working properly on your Frigidaire refrigerator. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire Refrigerators
Freezer and refrigerator are too warm
I understand that your Frigidaire refrigerator, model#FRS6R5EMB, is not cooling well. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure the temperatures are set to 0 degrees for the freezer and 37 for the refrigerator. Give your refrigerator 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire FRS6R5EMB Side by Side...
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
Hi, my Jenn-Air #JF12089AEPO bottom freezer drawer is beeping consistently and the temperature reading shows 18 degrees Freezer Max Temp. There is also a dry frosty crust on most of my frozen foods. How...
Make sure the freezer drawer and the refrigerator door are shutting properly. Sounds like air is getting in causing the frosty crust. Also be sure to reset the controls back to the original mid-way settings and allow a day or so for it to balance, if you have turned the fresh food compartment down to a lower temp it may cause a similar condition.
Feb 24, 2014 | Jenn-Air JFC2089H Bottom Freezer French...
Warm Freezer and How do I set or reset the defrost mode
smoke smell coming from fridge, open back cover and a smokey cloud came out of the compressor what's going on with fridge?
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
KitchenAid KSSC48FMS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
