Question about Garden
Twice put in a new battery and a few days later the battery is dead and the battery will not charge. Ariens zero turn mower
  • 341 Answers
Have you tried replacing the battery terminal ends? If not I would give that a try before anything else. Good luck!
Posted on Jun 21, 2009
Cub cadet zero battery is dead after sitting a few days.
This is an electrical issue, you have a short in the harness, can very well be the keyswitch...even though you turned it to the off position, it's giving the unit the impression that it's still in the on position.
BriMaxSmallEngineRepairCo
Gibbstown,NJ
Jun 02, 2014 | Garden
Battery will not hold charge
I think you should go for manual first after that it would be easy for you to solve your problem. I had visited this site past 2 months before for my vehicle and find it quite helpful may be you will also get something useful here Hyundai
Dec 22, 2017 | Hyundai Tucson Cars & Trucks
I have an Ariens 46"Hydro Model 936053. Tractor is 2 years old and thought I just had a dead battery.. After charging, I began mowing, after about 15 minutes the Blades stopped turning while still...
First: check the battery because if it was dead then it might not be any good... Then after replacing said battery, hook a volt meter up to your battery and it should read over 13.2 and might even climb up to 14+. Anything over 15.5 or so will cook your battery. Your engine died because the safety solenoid in the bottom of the carb lost voltage... but I am only supplying what I would do in this situation by using your description.
Oct 20, 2013 | Ariens Garden
BATTERY HAS FULL CHARGE WHEN I TRY TO START IT IT DOES NOT TURN OVER NO CLICKING NOTHING CAN SOMEONE HELP ME. ARIENS 1740
Check to see if the solenoid is getting power. On the solenoid there are 3 wires. Two big, one from the battery, the other going to the starter. The 3rd wire is what activates the solenoid. Using a test light or volt meter. See if its getting power on the small wire when you turn the key. If no power, ignition switch, safety switches or fuses. If you are getting power replace the solenoid. If you have 4 wires. Test the two smaller ones.
Oct 17, 2012 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
Okay, I have a Ariens, Sport Zoom, Zero Turn, 12 HP mower. The battery was dead. It has a built in kill switch for safety. If there is no weight on the seat the engine shuts down.The battery is located...
Hi Tina, yes you can do as you asked and this will bypass the seat switch. No there is no need to disconnect the battery as the wires are not live unless the mower is running. Regards Phil.
Apr 21, 2011 | Briggs & Stratton Garden
How do you pull the starter off of an Ariens zero turn lawnmower. I need to replace the starter.
Expose the engine and take off a few covers and you will accomplish your task young Jedi... May the force be with you................
Apr 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Battery goes dead over night
First thing to do is find out if it's the battery or the mower. Disconnect the battery and leave it overnight. If it's dead in the morning, you need a new battery. If not, you either have a charging problem (not likely if the battery isn't dead after using the mower) or you have a current drain.
Oct 22, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Ariens zero turn will not start
Have you done a load test on the battery? It may be time for a new one 300CCA. Plus the solenoid may not be working right. you will know more because of lack of information or symptoms.
Good Day.
Nov 07, 2009 | Ariens Garden
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
