I have an AMD Athlon FX 2 dual processor and am using Core Temp to monitor the temps of which are posting 44 to 50 while using my computer. Is this normal?
Your CPU usually has 56ºC of temperature under load, so 44ºC is a normal temperature, still, make sure your case has enough airflow, it can really make wonders for your cpu.
Also somebody else here had the same type of question: http://answers.yahoo.com/question/index?qid=20090207210838AA922iE
From my experience as long as its not running over 100 then you'll be fine. If you have any doubts about your computer overheating you can always apply more compound to the heatsink and also buy a bigger one where the fan runs faster to keep things cooler inside of the case and always remember to have the side doors on as well.
select the decimal written correctly in expanded form 4.9? select the correct place value for the...
(More)
SELECT THE DECIMAL WRITTEN CORRECTLY IN EXPANDED FORM 4.9? SELECT THE CORRECT PLACE VALUE FOR THE UNDERLINED NUMBER 0.0006_ 6 IS UNDERLINED? SELECT THE # that is written as a fraction correctly 34.5 1.448? select the # that is written in digits correctly one hundred and four hundredths?select the number that is written as a decimal correctly 9-10 and 3 45/100? thirteen thousandths in decimal form ? select the # that is written in words correctly 0.009 and 53.106?23.07 # written in words correctly?select the decimal written correctly in expanded form 1.06?select the # that is written in digits correctly six and four tenths?select the correct place value 1,034.22_11
