Coleman Patio Heater
Problem for Coleman (5040B750) Patio Heater
Pump not woking
By jenna_esquiv on Jun 20, 2009
I draind my hot tub and refilled it and now the pumpis not working .I can hear it running put the water is not coming out of the valves
Clarification Request
Posted by randyprevost on Jun 20, 2009
Shut it off!.
Make sure the water level is above any water intake lines.
Open the pump housing. When you drained the tub, did you also drain the pump? If so, you may need to prime it by filling it with water manually. Also, are there any valves on the pump itself that need to be closed or redirected from a "draining" posisition to a "filter" posisiton.
Solution #1
posted on Jun 21, 2009
Not Rated)
jjjarvan
Rank: Master
Rating: 81%, 11 votes
you most likly have an airlock. check the pump, it will have a filler spud on the top of the pump chamber, fill it with water before operating the pump. you may have to do it several times before it works. Don't run the pump long without water.
Was this helpful?
Yes
No
Popular Solutions for Coleman Patio Heater
Questions and Unsolved Problems for Coleman Patio Heater
Do you recommend Coleman (5040B750) Patio Heater?
Answer
Answer
What does OH mean on a hot tub control panel
Answer
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and... (More)
Answer
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but... (More)
Answer
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve... (More)
Answer
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Patio Heater:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
