Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
My kenmore elite bottom freezer OK but upper refrig at 70 F , model # 59675523400, is Saturday so moved food to back up refrig.... called sears & they told me July 1st was first repair day for service!!!
    Novelist:
  • 103 Answers
Hi: That's sears for you;They promise prompt service on emergency refrigeration. I'ts one of three things. Your defrost heater is out, your defrost timer is out, your freezer is so full of food you blocked the vents to the fresh food. I mentioned these in the most likely order. If you are not handy just empty the freezer and take a hair dryer to the back (being careful to avoid the plastic components) to melt the frost behind the wall that is blocking the air vents to the fresh food compartment. If you are handy look at your parts list or the breakdown at sears.com and find the heater. It will be behind the freezer wall at the bottom. See how it is removed and check it. It will be a glass tube with a metal coil in it. If it is broken it is bad and replace it. If it is ok look for the defrost heater and see where it is located. then replace it. Of course check to see if your food has blocked the vents first. I hope this helps, Jeff
Posted on Jun 21, 2009
Icicles on food in freezer
Shut it off for 1 hr or so.Is it hot it?R u opening n closen alot?Defrost at times.
Aug 12, 2012 | LG LFX25971ST Bottom Freezer French Door...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Compressor stop running on Kenmore model 596 75523400 can it be reset?
Hi and welcome to FixYa. I am Kelly
Is the compressor HOT to the touch? If so unplug the unit for at least 30 minutes and plug it back in.
If the compresor is cold then it may be stuck in the auto defrosting mode. When this happens usually either the 60 Deg F Bi-metal thermosat or a thermistor has failed. Items 30 and 31 this link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
(Evaporator
If that checks out then we start replacing the PTC relay and thermal overload on the compressor IF there is power to the compressor. Otherwise we start looking at temp controllers and themal fuses.
Items 10 and 11 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00011?blt=06&prst=&shdMod=
You make have to access the links above via this page http://www.searspartsdirect.com
Then enter your model number as 596.75523400 under find it fast / model search.
The other possibility is the electronic control item 5 under "controls":
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00006?blt=06&prst=&shdMod=
The only way to find out is to read out the circuits with a meter.
Thanks for choosing FixYa
Kelly
Oct 08, 2010 | Kenmore Refrigerators
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
How do you defrost freezer of Kenmore refrigerator?
best way is to turn off for 24 hours leave doors open and put towels in the bottom of refrig
Nov 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite SS Bottom draw freezer refrigator is a lemon
Hi!!! you have to change your freezer fan and bi-metal which are upgraded good luck..call manufacture and see if you have a service flash and covered under warranty..good luckk...
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
245 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
