Air is escaping from the top of the freezer door.
SOURCE: alot of ice builds up at the top part of the
yes. if the door seal is not making good seal then when the unit is running it will **** air in from where the seal is failing and create frost build up. need to inspect seal and make sure its making good contact.
SOURCE: Air escaping from my fridge-freezer.
The sound you are hearing is just the circulation of refrigerant through the system. More specifically it is caused by the changes of pressures happening when refrigerant passes through the capillary tube and into the evaporator, changing from a liquid to a gas. This is not dangerous at all.
SOURCE: WHAT ARE THE COMMON PROBLEMS WITH BLUE AIR 2-DOOR
Toll Free #
001-866-677-8500
FAX
001-310-808-0242 / 1-310-808-0262
E-mail
00Admin : [email protected] / Sales Team : [email protected]
sorry couldn't delete it. why not call blueair and ask them product info on that model and see what they say if there is any particular problems with that model. ask about warranty and recalls
1-310-808-0102
1-886-677-8500
[email protected]
hope this helps
SOURCE: Iced up copper pipe... both
Call back who ever fixed the leak, you still have one.
After fixing the leak make sure the drier is changed, system evacuated to at least 500 microns, then do a standing test. Meaning let the unit stand with the micron gauge connected. The unit should hold a vacuum. A slow rise indicates moisture, whereas a rapid rise indicates a leak.
