Question about Electronics - Others
Not heating up properly. Heating element is still
Not heating up properly. Heating element is still good. Test shows that it is still working. Will not heat up past 78 degrees. Keeps kicking off.
    Champion:
  • 225 Answers
Check the high limit swich.
Posted on Aug 04, 2009
Blower not getting up to speed
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irreparable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
good luck
rate these
Jan 10, 2013 | GE Profile Harmony DPGT750EC Electric...
Ge medallion 850 new elements and thermostats still not heating up
see this possible causes:
1) You must shure the heating element show continuity see the video>
2) Test for continuity the thermosta see the video how to do it
3)TEST THE thermal fuse, for open and replace.
4) Test any WIRES for loose, or broken or burn and repair.
5) If anything is o.k see the diagram. You must test the contact from the a) Timer for open, or dirty, or wires loose, broken or burn b) Test the selector temperatur for defective in order to get the heating element to work, and replace if necessary. God bless you
Jun 09, 2012 | Dryers
My dryer does not heat up? how do you check the heating element? Model #DE27T3WXFB
Hello there and thank you for choosing fixya
Please Closly check the following
Dryer tumbles, but there is no heat
Dryer takes too long
  • Check the lint trap
  • Check for proper air flow
  • Inspect the vent hose for kinks or dips
  • Test the heating element
  • Test the thermostats
Jun 29, 2011 | Dryers
My sarena electric oven is not heating up
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Necht element How to Repair Home Appliances
May 17, 2011 | Ovens
Quit heating
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
My dryer works but has no heat whats could be wrong
hello there
:please go through each of these steps that i have provided belw
investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
07fcef1.jpg Thermal Fuse
f9921fb.jpg Thermostat
17a0736.jpg Timer motor
Jan 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer runs but does not heat replaced the heating element a few months ago and fuses breaker box is good
hello there:
Please follow this troubleshooting guide that i will provide below
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
Thermal Fuse
Thermostat
Timer motor
function isValidEmail() { var emailAdd; emailAdd = document.all.infobar_EmailAdd.value; if(emailAdd == "" || emailAdd.indexOf("@")
Jan 25, 2010 | Dryers
Heating part of Indesit ISA60v tumble drying has stopped working. Can you give me info as to where to look im a Electical-tech cheers chris
Hello there chris
Proper Voltage
81f68d1.jpg Heating Element
97ed1ca.jpg Thermal Fuse
0a798b8.jpg Thermostat
7e97613.jpg Timer motor
Jan 13, 2010 | Dryers
There is no heat to dry clothes.what do I do?
My dryer will not heat up.Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 12, 2010 | Kenmore Dryers
Electronics - Others Logo
81 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
