Question about HP Lands Phones
HOW TO HOOK UP TO PC flashing red light - HP Lands Phones
Wait until the light is yellow and plug in the Flux Capacitor to the B port
Posted on Jun 20, 2009
I have a viper 350HV and I want to connect a 620v I just need to know what wires to hook it up to
Red to hot(red)other to ground(white).Ground on vehicles is white,home(where you live)is bare copper or green if industrial.Hook the red to red and other to ground.
Apr 09, 2014 | 1999 Toyota Camry Solara
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | Computers & Internet
I have an HP Compaq PC. A d530s running Windows XP Professional. When I turn the PC on, the power light flashes red 4 times (1 red flash per second). Pauses ~3 seconds and repeats the red flashing. Just...
A bad power supply, OR a bad motherboard. And I hate to tell you, but it's more common for the motherboard to fail first. Especially in those HP/Compaq slimline PCs.
It's because there's very little airflow, and system overheats and burns out. I've had many customers with the same issue.
The good news is you can still recover your data from the hard drive, just take the drive out, and hook it up inside another desktop with SATA connections, or get a SATA-to-USB adapter, they cost about $15
Sep 03, 2011 | HP Compaq dc7100 Ultra-slim PC Desktop
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
My husbands xbox has 4 red lights flashing we want to fix it now for free
when you have four red lights flashing, its usually because the controller or the av cables are not connected properly. so makes sure everything is connected and restart your xbox. If your still receiving problems call 1800 4my xbox.
Oct 24, 2009 | Microsoft Xbox 360 Console
Epson 2400 scanner red light flashing
Normally any new scanner fresh from the factory has a 'lock' which prevents damages due to transportation. Ensure it is unlocked.
S. Mohan
Feb 05, 2009 | Epson Perfection 2400 Photo Flatbed...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Led light
The light that used to stay on all the time is most likly the Power light(LED) The light that used to flash when you were using the computer is the  HddLED(Hard disk drive Light Emitting Diode) If you mixed them up it wil likly only light the wrong light.    I hope this helps.  If you wish to be sure you may be able to download the owners manual  the manufacture ?
Oct 02, 2008 | Gateway GT5220 PC Desktop
PFM 42B1 [HELP]
Count the flashes - This is an error code - Usually between 1 and 6 flashes followed by a pause.
Aug 30, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Nothing on unit front display but Red Record light (solid)
how do you hook a dvd player up to a Sanyo sdtv model ht27547 tv ?
Jan 18, 2008 | Televison & Video
Lands Phones Logo
37 people viewed this question
Top HP Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a HP Lands Phone Expert? Answer questions, earn points and help others
