WATER TEMP CONTROL PROBLEM i have no cold cold wash rinse cycle,only hot cold and that rinses in hot
    President:
  • 1,136 Answers
Hi, Sounds like the cold water side of the mixer valve has gone bad or has gotten plugged. Do you have cold water in the wash cycle?
Remove the hoses from the inlet valve and see if there is sand in the screens.
Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
No rinse or spin cycle but washes
Could be something as simple as the solenoid fill valves for the water if you using a different temp for rinse from the wash cycle (warm wash cold rinse) in that case the cold side of the valve could have failed, in which case you'd be getting hot water for the wash and no water for the rinse and, without the fill, the cycle won't proceed from that point.
Mar 09, 2014 | Haier Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Rinse cycle and cold/cold temp are not working
You either have a faulty cold water inlet valve or you have the cold water hose connected to the hot water inlet valve. Cheers
May 15, 2009 | GE Washing Machines
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
Hot water on cold water wash or rinse
hmmm..now that's really interesting..that's a function of the control board..methinks you have an error in the panel and control center.
Mar 09, 2008 | Kenmore 44072 Front Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
