Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
There is a buzzing sound, but the blades are not turning.
I found some bones in the unit when i cleaned it up. The unit seems to be hot when you touch the body surface (under the sink). I've already cleaned it up and the blades turns freely by hand. The unit is still under warranty.
  • 34 Answers
SOUNDS LIKE MOTOR MAY BE BURNED OUT.
IF SO, U CAN TURN BY HAND, BUT MOTOR
WINDINGS MAY BE FRIED SO IT WON.T RUN.
U MAY HAVE TO REPLACE. SEE IF U CAN
SMELL FOR BURNED WINDINGS.
Posted on Jun 21, 2009
It just buzzes
grinder blade is probably stuck or in a bind. Take a socket wrench with extension and from the top (sink), turn the nut and blade inside the disposal by hand to free it up. Can also unplug it and reach inside to see what may be lodged in the disposal (rag, bone etc).
Oct 22, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Intermittent buzzing sound at turn signal switch - 97 suburban
You found it. and you verified it the solution and the fix is the turn signal switch
Mar 17, 2012 | 1997 Chevrolet Suburban
My Lennox ac is making a very loud buzzing sound and the fan blades are not turning. We replaced the dual capacitor and that seemed to fix the problem for a couple of days, now it's doing the same...
Fan motor is probably bad, if it is under 5 years old the parts are under warranty. Do not run the unit for very long without the fan working as it can damage the compressor.
Aug 23, 2011 | Heating & Cooling
I have a Trane AC unit, model HIDE036506A which is about 14 years old. The fan and compressor all of a sudden stopped. I can start the fan by hand but the compressor sounds like it wants to start but...
sounds as if the fan motor is getting hot and going off on internal overload (safety). - which causes the compressor to heat up and also go off.
When this happens the usual 'fix' is to replace the motor although you can try replacing the capacitor.
Since you only see one (capacitor) it's possible it's a 'dual capacitor' which means it's the serving the compressor AND the fan motor.
I would replace the fan motor.
Note: I've seen 'shorted' fan motors before - where the blade just barely turns and you would not want to touch the blade because it will give you an electrical shock.
I would be very careful touching the blade of that motor with the power on.-
Jun 01, 2011 | Heating & Cooling
Rudd central unit , turn A/C on[therm. inside] all U can hear is a Buzzing noise coming from the outside unit , found that [1] capacitor wire had been BURNT , changed wire , then changed capacitor , turned...
Hello
Before you buy a new condensor fan motor check the contacts to the motor are not worn or pitted.
Hold or push the contactor in by using an insulated screwdriver and see if the fan motor turns.
Also the start cap you bought? was it the correct one meaning mfd micrfarad?
If all the above checks out ok then you need a fan motor,you can wire the motor direct to check it also.
From what you describe it sounds like the fan motor is burnt up and worn out,not uncommon.
Mar 22, 2011 | Heating & Cooling
Makes buzzing sound after cleaning blades
I keep the blades clean. Really clean. I'm a smoker, and you would not believe the crud that accumulates on those "blades"... <g>
First, I spray the blades with "PurplePower" cleaner/degreaser (from AutoZone), then I wipe them down with a sponge, then rinse with hot water. then dry them with compressed air (I have a compressor...).
FWIW, "Windex" works pretty good too, but... the degreaser really works well on the cigarette "residue"..
Second, there are two long wires inside that also have to be cleaned, periodically.
If your unit has the "pull-tab" cleaner, use it. One of my units has it. The other two don't.
On the ones that don't have the built-in cleaner, I stick a chopstick in through the rear vents, and CAREFULLY rub it against the sides of those wires, which "scrapes" the "white crud" off of the wires. Take your time. You will likely have to "change locations" several times in order to access the full length of both wires.
NOTE: those wires are fairly durable, but BE CAREFUL with them.
Either way, after cleaning the wires, I then "blow" the unit clean with compressed air.
Voila! No more buzzing. Until the next time the wires get "crudded up".
Mar 12, 2010 | Ionic Pro CA500 Air Purifier
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Air Conditioner Compressor Fan Quit
Check the start capacitor. You may be able to see visual deformaty, otherwise, use a meter. The buzzing is most likely the contactors closing which uses a seperate 24v supply..
Jun 26, 2009 | Kenmore Heating & Cooling
Can't separate blade unit from jar, but managed to make it leak
Put it in hot water for a few minutes and then try to unscrew it.
Dec 31, 2008 | Blenders
Excessive noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Oct 26, 2007 | Ionic Pro TURBO Air Purifier
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
384 people viewed this question
Top Buck Home Experts
Gene Haynes
handygirl911
handygirl911
salaberrios
salaberrios
Level 1 Expert
Are you a Buck Home Expert? Answer questions, earn points and help others
