Question about Refrigerators
REFRIG. DOOR HANDLE GETTING LOOSE
G.E. FRIDG..
  • 3 more comments
  • dan1935 Jun 21, 2009
    just a smal hole 1/8" dia ,s/b a pin or asmall screw ,I cannt figure out.l
  • dan1935 Jun 22, 2009
    model # gss 25qu sta ss
    ser. # am434456
    made in MEXICO
    Model # gss 25 qu sta ss
    serl. # am434456
    made in Mexico
    no I have diff. handle , just a long curve.
  • dan1935 Jun 23, 2009
    YES ! THX. I DID IT
    President:
  • 1,136 Answers
Hi, look at the ends of the handles and see if there is an end cap that can pop off. Sometimes there is a cap the whole length of the handle. Pop off the cap and there should be a screw holding the handle on.
I hope this helps you. If there are no caps, get me a model# and I can look this up for you.
Thanks
Vic
Posted on Jun 20, 2009
  • 2 more comments
  • Victor
    Victor Jun 21, 2009
    It could be an allen/hex head screw. If you will get me a model#, I can look this up
  • Victor
    Victor Jun 22, 2009
    Does this look like yours?
  • Victor
    Victor Jun 22, 2009
    This looks like it. There is a small screw that you can tighten
  • Victor
    Victor Jun 23, 2009
    You are welcome
Have an Amana Side by side refrig/freezer (model ACD2234HRS) that has a loose refrig door handle. How do you get access to tighten the door handle screws?
i believe there are plastic coverings that just pop off. they are located at the hinge,you will need to fully open the doors to get to them.
Sep 20, 2009 | Freezers
Refrigerator door handle is loose how do I fix it?
some come off when you pull straight up if there are no visible screws. then tighten the screws on the inside of the handle that fasten into the clips on the door.
Jun 12, 2009 | Refrigerators
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Mar 25, 2008 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Fridg
water line in freezer door is froze up. Call GE customer service to see if your ref. has a service bulletin.
Jan 05, 2008 | Hotpoint HSS25GFP Side by Side...
GE Refrigerator side by side loose door handles
I was actually trying to find a solution to this problem myself though I'm pretty sure I already know the solution. Try this: grip the handle that's loose firmly and jerk it up. The handle should come up and the straight out to reveal the spring clip mechanism holding the handle on. Tighten the screws on this and then put the handle back on by pushing it towards the fridge and jerking it down. You make want to protect the fridge above and below were the handle attaches so you don't scratch the fridge door when pulling the handle on or off.
Oct 29, 2007 | GE GSH22JFR Side by Side Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
