Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Inoperable Soap Dispenser
My soap dispenser ran out of soap. When I filled it up, it no longer worked. I tried pulling the plastic tube out and the whole thing came apart. Two ball bearings fell out and I can't tell where they were supposed to go
  • 297 Answers
If the balls fell out you need a new head,sorry.
Posted on Jul 15, 2009
Water does not drain from dispenser into tub/drum fast enough
pull out the dispenser,check inside where the dispenser goes into,i found in two washers the white circle piece that's inside the cap to detergent,when water would go in the cap would block the fill tube,if you checked the dispenser and water flows through you have something blocking the fill tube,hopefully the washer and dryer are not stacked,you might have to take the top lid off to get at the fill tube or fill hose to clear it.good luck with your washer
Dec 25, 2014 | Washing Machines
Fix soap dispenser
remove the entire soap dispenser and clean out any dried soap which may be lodged in the pick up tube, blocking the pump
Aug 26, 2014 | Plumbing
Filled Blanco Alta soap dispenser from the top and have had issues with it ever since. The plastic straw repeatedly disconnects and even when it seems to be firmly inserted, the pump doesn't really work...
Get the plastic guts of the thing apart (again, I know). Soak in CLR, was thoroughly in warm water and dry. Squarely cut back the original squarely cut end of the tube about one-half inch with a razor knige. Reinstall the tube FULLY onto the base of the pump as far as it will go.
I no longer refill from the top. I now bite-the-bullet and crawl underneath in the cabinet, unscrew the bottle and refill.
Feb 21, 2011 | Blanco Alta Soap/Lotion Dispenser
The soap dispenser door will not open. How do I remove the top of the washer to access the soap dispenser? I know that the blue plastic piece for the fabric softener lifts up when I try to pull open the...
To remove top: Remove the bottom screw from the plastic clips on back of the washers top. next, stand in front of machine and, using the palms of your hands, sharply push the top back about 2 inches, allowin you to lift the top off.
Dispenser issue: you may have to drill a small hole in the plastic top of the dispenser to allow you to push the offending part down while pulling on the drawer. seal the hole with silicone or foil tape.
Feb 20, 2011 | LG WM-2277HW Front Load Washer
GE Harmony top load washer: The soap tray when filled with liquid soap will not properly dispense the soap when the water is filling the machine and the soap tray remains full of water and soap at the end...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 11, 2011 | Dishwashers
I have a Grohe soap dispenser and it has quit working for me. It is as if it gets stuck after you push it down and it seems to leak the soap out of the bottom part of the dispenser getting soap all over...
Sounds like there might simply be old soap caked on the inside of the dispenser head and feed tube. Best thing to do is have a sink filled with HOT water and just put the head portion in there to soak for a while. This should loosen the old soap enough to either dissolve or at least get it moving again. You can also take what soap is still in the dispenser out and put in another container, taking time to rinse the container with hot water as well and then filling it with hot water as well to test the pump action of the head, again using this action to help clean the insides of the pump. Short of this doing the trick, it may just be time for a new one. Good luck.
Aug 26, 2010 | Grohe Satin Nickel Soap Dispenser...
We have the single handle Pegasus 190 571 Brushed Nickel bathroom faucet. The soap dispenser got knocked and broke off and I cannot find a replacement for it.
The booklet that comes with that unit has the following part numbers: nut set (A66D111); soap dispenser sleeve (A665597); soap pump (A605230); soap dispenser nozzle (A66596). Those are all the parts (less plastic tube and soap reservoir bottle) for the dispenser- you probably only need one (the broken one!).
Jun 17, 2010 | Home
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
Soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Dec 11, 2008 | Grohe Satin Nickel Soap Dispenser...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
303 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
