Question about Garden
18 HP Briggs and Stratton OHV Model 31M777 runs rough
Single cylinder - ran good set a week started up runs rough won't come up to high speed. Does not die but sounds like it is running in slow motion. I changed fuel filter- air filters- spark plug ( old one looked almost fouled out. No change
  • panilling9
    panilling9 May 11, 2010
    check carb. to be sure it is not loose
    and be sure the choke is not partially closed due to a loose cable at the choke cable or throttle control cable
    Problem Solver:
  • 18 Answers
Have you checked the choke? Sounds like it might be stuck closed or partly closed.
Posted on Jun 22, 2009
Briggsload Stratton 14.5 HP single cylinder OHV gasoline engine has episodes of severe smoking when
When what if you are saying when starting..after sitting..the oil from your overhead valves are seeping into the heads through open valves..when not running..most likely bad valve stem seals...
Apr 12, 2014 | Briggs & Stratton Garden
Gas ran out of sparkplug hole
If you had raw gas in the cylinder to where it poured out of the plug hole you most likely have a carburator problem. Inside the carburator is a float and needle, the float pushes the needle into a seat when the bowl is full of gas so no more gas will flow into the bowl or the engine. If the float won't float or the needle is damaged or has dirt between it and the seat the gas will continue to flow into the carburator and on into the engine. If enough gas gets into the cylinder the starter won't be able to turn the motor over. You should also check your oil, usually when gas gets into the cylinder it runs into the crankcase and thins the oil to where it will damage the motor if run for any length of time.
May 09, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
What is the high speed rpm setting for a intek 22hp vtwin?
Generally 3,600 rpm is the high speed setting for many of these type of engines.
Mar 03, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My Briggs 18 hp v-twin is starved for fuel. It
A more likely cause is a clogged jet in the carb.
Remove disassemble and clean Carb, the High speed idle jet is clogged.
If you had a fuel pump problem it would not run even in the Choke mode.
This tends to happen when an engine sets for long periods of time with out a fuel inhibitor id is even more likely to happen if you use fuel with ethanol.
Hope this tip helps.
r/David
Jan 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
485 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
