Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500
Trimmer only works on full choke
25cc trimmer only works on full choke. At half choke or run positions the motor dies. It was recommended to me that I remove the 'spark arrestor' that is situated next to the muffler. I opened the machine took the muffler off, but what does a 'spark arrestor' look like?
Dan
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Thanks for the rating Dan!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
The trimmer starts fine, but as soon as touching the trigger, it dies. Even if you wait, it runs fine until yu touch the trigger and it dies, every time.
Most symptoms and problems such as you report, are commonly resolved by the following, check, clean, or replace:
  • fuel filter - located in the gas tank
  • Spark plug
  • Spark Arrestor- screen at muffler. When clogged up with carbon build up, engine no longer operates well
  • Carburetor- may need a new rebuild kit
And watch this...
And this one..
Oct 09, 2014 | Poulan Garden
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Start up with no problem. It does fine as long as i do not give full gas. Only then does it choke.
It sounds like the spark arrestor screen in the muffler is clogged with carbon. You may have to look at the muffler to find where the spark arrestor screen is. It is in a different place on each brand of trimmer. You can clean the spark arrestor screen after it is out or off of the muffler by burning it with a propane or similar torch. This will cause the carbon to get hot enough to ash off of the screen. Then you can put it back in the carburetor.
Fuel mix is too heavy on oil, or if you run the trimmer at half throttle a lot this can cause the carbon buildup.
I hope this answers your question.
Apr 02, 2011 | Troy Bilt Tb70ss Gas Trimmer
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
My trimmer seems like it needs a new air filter or air filter cleaning, I cannot find the air filter on it. It is a 31cc Craftsman Convertible. Help. It seems like it only wants to run in choke position,...
It should probably be behind a small cover at the back of the machine. The running issue is carb related any you may be due for a rebuild or decarbonization of the spark arrestor/muffler and/ or engine exhaust port.
Jun 13, 2010 | Craftsman 25cc Gas Line Trimmer
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
GAS TRIMMER WON'T START - BUT ALMOST STARTS WHEN I POUR GAS IN THE SPARK PLUG POCKET, THE GAS THERE DRIES/DISAPPEARS FAST. MUST BE A GAS LINE SITUATION? WHAT SHOULD I DO?
The gas is going into the the crankcase. When the piston goes down it opens the ports and allows the gas to go down untill it could fill the crankcase. Start by blowing compressed air into the spark plug hole and allowing the piston to go to it's lowest position. This will usually remove any liquid gas from the crankcase. Next get yourself a small spray bottle and fill it with the same gas mixture your trimmer uses. Now you can spray a small amount into the spark plug port, replace the spark plug, full choke and pull till it pops. set to half choke and pull. I have also sprayed into the carb but you must open the throttle to allow the gas to enter the combustion chamber. Spray,close throttle,pull choke and pull. You may need to do this a few times for it to start. After it starts let it run at half choke for awhile until it warms a bit then open choke and go to full throttle. If this dosen't work it's possible to have other problems.
Apr 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
4 cycle cub cadet will start but as you increase RPM it dies
Check at the exhaust port. Clean out any carbon buildup there. Believe me, it makes a big difference. Hope this helped and best wishes.
Sep 04, 2009 | Craftsman 25cc Gas Line Trimmer
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Jun 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan 25cc 2-Cycle Gas Powered String Trimmer with Curved Shaft #P1500 Logo
709 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
