Question about GE JVM1339BW/WW Microwave Oven
GE Spacesaver XL
My GE Spacesaver XL microwave oven model JVM1339WW has the following problem:1. Turntable does not work2. No humming sound ( fan, etc. )3. Does not heat I can hear a clicking sound on the touch pad when I hit the stop button.
    Problem Solver:
  • 8 Answers
Fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – karlet@bellsouth.net
Posted on Aug 21, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
  • 108 Answers
SOURCE: GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Posted on Nov 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: G.E. Spacemaker microwave turntable won't turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 16, 2008
  • 64 Answers
SOURCE: Have a GE microwave spacesaver oven/Model
call a pro. these units run at a deadly high voltage. simply not worth your life!
Posted on Jul 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacesaver Microwave touchpad
You almost certainly have a bad membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a
handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
My microwaving is humming
just about all microwaves hum-----the fan,turntable motors make a hum if louder than normal check that turntable it not stuck or off track
Sep 07, 2015 | GE Spacemaker JVM1640SJ Microwave Oven
The turntable on my GE spacesaver xl 1800 stopped turning. The model number is JVM1850BH01 I would appreciate any help.
On this model, the power to the turntable motor ("drive motor") is supplied by a tap (outlet terminal) on the internal cooling fan motor.
The other side of the turntable motor's power is switched on and off by a relay on the control circuit board.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
If the cooling fan is running, but the turntable is not, then it's probably a relay issue or connection which we can repair.
dee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 30, 2011 | GE XL1800 1100 Watts Microwave Oven
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacesaver XL Sensor Microwave
You have a bad door swicth or a bad wiring connector to one of the door switches... secondary swicth or the door sense switch.
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
Microwave Ovens Logo
196 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
