Question about Maytag Neptune MAH5500B Front Load Washer
Neptune front load washer
How do i get the top open to fix a leak?
  • sbonnbonn Nov 03, 2007
    thanks for trying, we removed the screws already, there looks like henges on the back, but we cant find how to get the front undone to lift it up.
Remove the detergent bin. Towards the front under the edge is a plastic wire. Pull this to manually release the door lock
Posted on Nov 04, 2007
  • 1,294 Answers
Look for screws on the top cover, normally behind the machine. Take off the wall plug before handling the thing........
Posted on Nov 03, 2007
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer is leaking out of front door, its a front load washer
There are a couple of steps to be done to fix the issue. Please follow the steps provided in the bellow mentioned link:
Thank You
Sep 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Water between the drum even when not on
Water between the drum is a common problem with not only front load but top load as well.
Front load washers such as the neptune have an airtight/water tight door which will hold moisture in the machine when closed. Try opening door and keep open between loads. In addition, a monthly cleaner specific for the front load machine will help this problem
May 29, 2009 | Maytag MAH6700AWW Neptune Front-Load...
How do I open the top of my front load washer (Neptune Mod. MAH3
there 3 screws on the back u take off but to take door latch off u dont need top off u open your door take the spring off the front of your boot then remove the screws from door latch reach back there behind boot unplug put new in and put back togather
Apr 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water leak from bottom of Maytag Neptune washer
The water pump is cracke,. replace the water pump. Peter
Mar 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leak
you would acess ut from under the main top. alittle involved but acessable,.. you need to remvoe teh four phillipsscres from with in the soap dispensor area. then remove the front door as well as th e2 screws oppisite t eh door hinge, then pop off the front cover. from there youll find 2 more 5/16 screws holding the top to the frame assy. then the main top can be flipped backward allowing you acess to the valve
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Changed boot but still leaks
Are you sure it is leaking from the boot seal? The water could be leaking from the top or front of the washer and running down along the door. Pull the top off and watch the machine while it fills. Use a torch for better viewing.
Nov 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
