Question about Whirlwind FH-778 Air Conditioner
My central ac unit started blowing hot air instead of cold, we turned off the ac and left it off about 6 hours, i turned it back on and still hot air after 10 min of running, the coils are not froze up and the pan under is bone dry
  • edrobinson1 Jun 20, 2009
    ac was serviced about a year ago, it is about 8 years old
  • Randy Prevost
    Randy Prevost May 11, 2010
    You may need to get a service person in the recharge your system with freon. How old is it, and when was the last time it was serviced?
    Sergeant:
  • 340 Answers
Condensing unit is not running check the circuit breaker , thermostat on cooling? is this a window unit if so compressor has problem
Posted on Jun 20, 2009
  • timothy thompson Jul 28, 2012
    You can also push contacter in or use a volt meter to check for 220 to the contacter.
  • 3 Answers
Could be a number of things make sure the unit outside is running both fan and compressor.If not check breaker,stat,24 volt wires going to condensor they get hit with weed eaters a lot or just need cut and stripped and wire nuts replaced.
Posted on Jul 28, 2012
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Why does my 2005 GMC truck air conditioner will blow cold air then hot air?
possibly low coolant, that will make the clutch disengaged and you get hot air instead,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jul 22, 2014 | Heating & Cooling
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Ac BLOWING HOT AIR INSTEAD OF COLD. All of a sudden my AC started blowing hot air instead of cold. It is set on cool.
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Apr 18, 2009 | Hunter 30124 Air Conditioner
Central a/c
check to make sure that the kids didn't change any other settings. Is the themostat still set for cold not hot? Also check the temp setting. Hope this helps.
Sep 11, 2008 | Heating & Cooling
Ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Mar 26, 2008 | Hunter 30124 Air Conditioner
Heating & Cooling Logo
483 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
