Question about Heritage Pool & Spa
Just set up a used heritage hot tub. Temp is up to 90 degrees but I can't turn off jets. It says push button once for low twice for high and third time to turn off. What am I doing wrong can only get high and low
    Top Expert:
  • Heritage Master
  • 8,861 Answers
Or possible relay bad
Posted on Nov 23, 2017
  • 93 Answers
Make sure timer is not set on it will not turn off push all tabs on timer in that will solve problem
Posted on Jun 20, 2009
I just bought a used older garden leisure spa, it won;t turn off. The manual says push button once for low pump, twice for high pump and a third time for off. I only get low and high pump speeds.
This can be normal depending in the settings. It may continue to run for upto 15 minutes, its just looking to satisfy it's heat or filter cycle.
Dec 14, 2016 | Pool & Spa
How do I get my hot tub back to standard setting instead of Economy mode
This is a combination of buttons on your topside. Either push the mode button and the up/down arrow of the temp settings or the jet button the up/down arrows of the temp setting.
Rod
US Parts Center
Feb 04, 2013 | Pool & Spa
Our jacuzzi is almost regular tub and has tow metal buttons, one on the top/edge and the other near jet mouse at the middle level of bath tub. We have not used our jacuzzi for 10 months. Even we only use...
The metal button on the top of the tub is used to turn the tub on/off. the metal button you see in the middle of the tub above one of the jets is the low water sensor.
the water has to be above that metal tab, you have to be in the tub and then touch the metal button on the top of the tub to turn it on.
this system uses the electrical current from our bodies to complete the circuitry and turn it all on and off.
Feb 12, 2011 | Home
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Is it more cost affective to leave the hot tub on all the time or turn it off and reheat it
it depends on how often you use it and if you have a good cover with thermal value. If you use the spa more than once a week, then it's probably more cost effective to leave it at temperature. If its more like once or twice a month, then probably better to lower the temp. My spa uses about $30 per month of power leaving it at 104 degrees.
Sep 24, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
How to reset alarm on heritage softail, bike wont
Set the alarm by holding the key fob button until you see running lights flash twice. Turn off the alarm by pushing the key fob button twice and the lights will flash once.
Aug 29, 2009 | 2000 Harley Davidson FLSTC Heritage...
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Nov 11, 2008 | Sport & Outdoor - Others
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Pool & Spa Logo
258 people viewed this question
Top Heritage Pool & Spa Experts
john h
ray gallant
Mike Raino
Level 1 Expert
Are you a Heritage Pool and Spa Expert? Answer questions, earn points and help others
