Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Shows red, bulbs out?
My screen picture shows like this ) ( but at top and bottom. Shows more red than other colors and tends to cut off from time to time.
  • 25 Answers
Sounds like a convergence board problem. a certified tv technician can check and realign convergence for you.
Posted on Jun 24, 2009
BLACK SCREEN WITH RED ON TOP RIGHT ON SONY WEGA TELEVISION
Optic Block failure. Lamp wont help you there unfortunately. The KDF60WF655 was a good TV back in its day. Don't waste your money on repair and return the lamp if you can.
Jan 04, 2018 | Televison & Video
Shows red and yellow line on top of screen
the lcd panels are broken, you need a new one
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Apr 05, 2012 | Hitachi Office Equipment & Supplies
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb...
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
Dec 27, 2009 | Toshiba 50HM66 52" Television
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Having picture problems 61 in phillips hdtv
Replace the STKs IC on the convergence PCB.
May 18, 2009 | Televison & Video
Phillips rear projection tv model #60pp9202/17f
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2008 | Philips 60PP9202 60" Rear Projection...
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
