Hotpoint Ultima WF860 Front Load Washer Logo
I
Ian Thompson Posted on Apr 26, 2014
Numbers on LCD screen
The numbers on the LCD screen aren't coming up fully formed there's only half the number shown and can't select a 40 wash everything displaying as a 90?
Iftikhar Ahmed
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 20, 2014
Iftikhar Ahmed
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
44
Points
Its likely that stored it as a default programme
2 Related Answers
Anonymous
  • 712 Answers
  • Posted on Aug 20, 2010
SOURCE: just to start where do
Most probably it is located on the rear side of the machine. You can see it inscribed somewhere on the top of the rear side.
caroldon
  • 17130 Answers
  • Posted on Dec 29, 2011
SOURCE: water in cycles is always cold
You need to check the heating element continuity using a multimeter. If there is continuity then check voltage at the time of the heating , if there is no voltage then the control panel is a suspect including the relay to the coil.
I want to clear the blocked calls from my Panasonic ox-TGIF 370 phone
Do you mean the Panasonic KX-TGF370 base for a cordless phone system? Depending on the number of handsets, the model number could be KX-TGF372 or KX-TGF375. This base also came with the KX-TG585SK.
From the handset to clear the blocked call list, press the Call Block button (below 0). Use the up/down arrows to choose whether you are dealing with a single number or a block of numbers. Press the soft key for Select. To erase one number, scroll through the list to the number to remove. Press Select and then choose Erase. Confirm this by highlighting Yes and pressing Select. Press Off to leave the menu system. To delete all of the numbers in the call block list, press Menu (see the LCD screen label for the soft key) after choosing the Call Block single number or block of numbers option. After pressing Menu, use the arrow keys to choose Erase All. Press Select and then confirm the choice twice by choosing Yes and pressing Select each time. Press Off to exit the menu.
From the base, press Menu (center soft-key) followed by # (below 9) 2 1 7. From here follow the directions above, with one exception. Press Exit to leave the menu system. You can press Menu and then navigate through the menu with the arrow keys to choose Call Block and press Select.
These steps are shown in the manual available from the Panasonic product page: https://shop.panasonic.com/support-only/KX-TGF372S.html . The current link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tgf372_en_om_.pdf . See page 34 for the complete directions; page 45 shows the section of the menu tree.
I hope this helps.
I have a candy bianca washing machine and all lights just flashing with numbers onit and does its own cycle for a minute then stops then lights flash again any help guys
Hi all I have a candy bianaca washer dryer. When I switch it on it says welcome amd then shows long numbers across the screen. Wont let me select a wash or anything. Does its own cycle when turned on then lights continuously flash and doesn't do anything. Please help
1helpful
How do I distinguish between the numbers on the program guide ie- My instruction manual guide starts with program 1_90; 2- 60 etc until it gets to 9-40 mixed wash, then it goes to 1-60; 2-50.
The first part of the number is the wash cycle which will correspond to the cycle selector, the second part of each number is the selected wash temperature
There is a faint line in the bottom half of my LG tv lcd screen
the projector is out of alignment making the bottom ghost. They are expensive to replace.
2answers
1helpful
2answers
I have registered my Brother MFC 9840CDW on the brother website but it still says "not registered" when I try to email a scanned document. I registered it online. Do I have to do anything on the...
If the LCD shows Not Registered when you enter a One-Touch or a Speed-Dial number, it means that an email or number is not stored there.
If you selected E-Mail and save the E-mail address, you can only use the E-mail address when you are in Scan mode. If you selected IFAX and save the E-mail address, you can only use the E-mail address when you are in Fax mode.
Your machine has 20 One-Touch keys where you can store 40 fax or telephone numbers or E-mail addresses for automatic dialing. To access numbers 21 to 40, hold down Shift as you press the One-Touch key
You can dial in any of the following ways.
Manual dialing
Use the dial pad to enter all the digits of the telephone or fax number.
One-touch dialing
Press the One-Touch key that stores the number you want to call. (See Storing one-touch dial numbers on page 60.)
To dial One-Touch numbers 21 to 40, hold down Shift as you press the One-Touch key.
Speed-dialing
Hold down Shift as you press Search/Speed Dial, and then enter the three-digit Speed-Dial number. (See Storing speed-dial numbers on page 61.) Three-digit number
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Tv is normal but when heats up half screen goes red??
It sounds like the LCD controller (t-con) board is bad, try removing the back cover and cool down the board with a samlle fan blowing on the board, you can see what the board looks like here or buy the replacement, but you need to get the numbers pronted on the board since your TV has more than one version as shown on the website: http://www.shopjimmy.com/catalogsearch/result/?q=Philips+42PFL5332D+
I have installed a new black cartridge but print is not clear. i think i need to realign cartridges but dont know how. it is a lexmark x73. can you pls help
1 Select Print Control Program Cartridges Align Cartridges. For help, see page 8.
An alignment page prints and the Align Cartridges dialog box displays on the screen.
A number appears under each pattern. The test page that prints is similar to the one
shown.
2 For each alignment group on the test page, find the number that comes closest to
forming a straight line.
3 In the Align Cartridges dialog box, enter the numbers you selected on the test page.
4 After you have entered a number for all of the patterns, click OK.
http://www.lexmark.com/publications/pdfs/2007/x73/user_guide_en.pdf
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
