Blows Hot Air - Full of Fluid - Could it be the fuse - Where to look for fuse
  • 3,230 Answers
Most of the common cause would be a slow leak in the system, and Freon might have been lost, causing warm air to blow. There also can be lots of other possibilities. Try going back to the shop where the care was done or a different one to see what they find. Air conditioning work requires lots of equipment and is not really a do-it-yourself repair.
Simply recharging an A/C system never fixes anything. An electrical problem may have occurred if there is a leak. The system has three major components and a few smaller ones. Most of the time, your problem lies in at least one of the three big ones: compressor, evaporator, and condenser, not looks like the fuse.
Thanks
Posted on Jun 20, 2009
Heater stops blowing heat and temp gauge goes up! Heat blows hot again and temp gauge goes down
This is usually caused by air in the cooling system. While the engine is cool, check your fluid level in the coolant tank. Then check the radiator to make sure it is full. If both of them are full, the system has to be bled. To bleed the system, take the radiator cap off, start the engine. If there is air in the system it will bubble out and the fluid level will drop, add coolant until this stops.
Sep 20, 2011 | 1999 Chevrolet Malibu
All heat settings work fan blows but theres no hot air cold??
check your radiator resivior, make sure that there is antifreeze up to the full when hot line, if your low on fluid the first thing you lose is heat.
Jan 26, 2011 | 1995 Audi 90
Hi, i have a 1992 honda accord aerodeck with the 2.2 efi engine.. My problem is that i can only get cold air :( even when the knob is turned on full wack to hot it still only blows out cold!! I replaced...
take the radiator cap off when the engine is cold check the fluid in the radiator,if necessary add fluid to the radiator not the resevoir with the motor running and with the heater on until full leave the cap off untill the motor gets up to full heat and the thermostat is open and pulls the fluid into any unfilled cavities. Add fluid as necessary.
Dec 22, 2010 | 1992 Honda Accord
2001 ford escort zx2 has no heat. Blower OK, AC fine. I did notice the temp guage fluctuates quite a bit. When I select full hot, will get warm (NOT hot) air for about 30 sec. then it blows cold. Could...
It is much more likely you are low on coolant or you have an air bubble trapped in the cooling system. You should bleed the cooling system to get any trapped air out and make sure it is full of coolant.
Dec 14, 2010 | 2001 Ford Escort ZX2
I have a 2001 Hyundai elantra, and the engine temp sensor gets to the middle line, but no hot air blows. the fan blows cool air unless im at a higher speed around 70 mph, and even then there air is only...
2 things it maybe. Your blend door may be stuck open. 2nd Your heater core may need replacing. Check to see if both heater hoses are hot. 3rd heater control valve maybe bad. Good Luck!!!
Nov 03, 2010 | 2001 Hyundai Elantra
I have a toyota voxy 2002 an the a/c light keeps blinking an no cooling its just blows hot air i have checked the a/c gas is full,i have changed the a/c fillter but still it blows hot air,
open the bonnet,start the engine let it turn on idle, then put the a/c on you will hear a click noise which mean the compressor is being coupled to the engine via the belt.If not check the fuse of the a/c.
Oct 04, 2009 | Air Tools & Compressors
Air conditioner just -barely- cools.
im not sure what you are trying to ask but it sounds to me like your blend door is not switching
Jun 13, 2009 | 2000 Jaguar S-Type
2001 pt cruiser no heat
did you check the fluid level by removing the rad. cap? Radiator should be full to top. If Chryslers are low on coolant, the heater will not blow warm air.
Jan 04, 2009 | 2001 Chrysler PT Cruiser
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
A/c blows cold parked then blows hot after a few miles
engine fan not kicking in at right interval to bring air in so its pulling in hot air threw ducts
or you have a disconnected duct blowing all air out not to right place
guages could be faulty or bad a/c relay
Jun 10, 2008 | 1993 Lincoln Town Car
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
