Washer does not drain and spin
Sometimes our washer does not drain the final rinse and do a final spin
    President:
  • 1,136 Answers
If this a whirlpool brand washer, check your lid switch. When they start going bad, they can be intermitent. While the washer is in the spin cycle, if there is no motor noise, push down on the lid above the lid switch and see if it starts.
This is the most common issue.
I hope this helps
Vic
Posted on Jun 20, 2009
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washer won't rinse & drain
The lid wasn't locking in all the way- when we put something heavy on top of the latch it started working.
Sep 15, 2009 | Whirlpool Washing Machines
Front load washer, will not do final rinse
A lot of times it is the strainer clogged at the pump. Hope that helps.
Sep 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Clothes still wet after final spin
Possible timer or drain problems.. ok.. when your washer is in rise.. before it goes into final spin.. it stop agitating, then drain water for about a minute or two.. listen to see if stop drain for a sec, then began to spin... when it come to draining.. make sure that you hear all the water flow out of your washer.. sometimes when you have a slow drain.. that can do it too.. but the first possible is likely.. good luck
Jan 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills, drains, & final spin
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
