Question about Brother MFC 9880 All-In-One Laser Printer
Brother MFC 9880 - When I copy a document using the flatbed feature I get several black lines or strikes at the bottom of the photocopied page. If I use the automatic feeder the photocopied page is perfect. What is the problem please? Franco
    President:
  • 1,314 Answers
Your glass is dirty. The reason you don't get it from the ADF is because it uses a smaller different glass ahead of the glass that you use when you put it on the scanner. Clean the glass using a lint free cloth and some glass cleaner or, better yet, lens cleaner.
Posted on Jun 20, 2009
  • Kevin Shafer
    Kevin Shafer Jun 21, 2009
    And why the bad rating? You asked what the problem was and I told you. Clean the glass and it will work.
Why is there a black line on copies when pages scanned with automatic document feeder but fine when using the flatbed scanner?
Different paper path, the MultiFunction unit is dirty - Most likely toner inside the roller or paper path. Try a laser cleaning cloth that you can buy in some stores or online. Search: Staples
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Aug 05, 2014 | Brother MFC 7360N - Multifunction fax /...
Can i convert the brother mcf 7340 to wireless
i dont know that you can -- you may be able to buy a wirelss adapter for it .. but according to the specs its a 5 in 1 , and wirless capable is not indicated in the specs -- dont take my word for it, call brother 1-877-276-8437
these are the specs i found for your printer
do you have a manual ?
OVERVIEW: MFC-7340 The MFC-7340 is ideal for any desktop or small office with its compact, space-saving design. Get the most out of razor-sharp printing. Make quick copies or send/receive faxes without the use of a computer. Enjoy the convenience of having a high-quality colour scanner, too. Scan multiple pages using the 35-page auto document feeder. Its advanced capabilities allow you to scan to a file, image, OCR or e-mail- all with a touch of a button! FEATURES: MFC-7340
· Fast black and white laser printing
· High quality output even at top speed
· High quality flatbed colour scanning
· Full-featured fax capability with broadcasting and auto-dialing
· Compact, fits almost anywhere
· User-friendly software with easy installation
· Interactive help software
· Cost effective, with high-capacity replacement toner cartridges
· Machine-lifetime toll-free technical support
Brother and its logo are trademarks of Brother Industries, Ltd., Japan. All specifications are subject to change without notice. All registered trademarks referenced herein are the property of their respective companies.
Oct 16, 2010 | Brother MFC-7340 All-In-One Laser Printer
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Feb 06, 2009 | Brother MFC-9440CN Laser Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
SOLID VERTICAL LINE ON AUTO FEEDER COPIES
Hi Sally,
Open the flatbed lid and look on the left side, I believe there is the flatbed glass and another piece of glass to the left, the small strip of glass is the one used for the automatic document feeder. this piece af glass needs to be clean or you will get a line from top to bottom from any type of speck on the glass. hope this helps... if so please mark as FIXYA!!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Oct 24, 2006 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 9880 All-In-One Laser Printer Logo
176 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
