Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsamen 18.5 hp battery keeps draining
Craftsamen 18.5 hp riding lawnmower ive bough 2 batteriesy and after a little use it keeps draining,and wont start,, what do u think might be the problem,, any suggestions please let me know
  • 87 Answers
Either the battery is not being recharged when the engine is running or there is a current drain when stopped. If you are not knowledgeable about electrical tests you can check for current drain by disconnecting the battery negative cable when not running. If the battery stays charged then you need to find the current drain. To check for no charge when running, turn on the headlights with the key on but engine stopped. Start the engine and see if they become somewhat brighter. If brighter, the charging system works. If not, there is a problem in the charging system which needs to be confirmed with a voltmeter.
Posted on Jun 20, 2009
What battery does a 48" deck riding mower take
I would put in the largest amp lawnmower type battery you can get
Aug 07, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Month or two the riding Lawnmower tractors battery goes dead?
You can test the charger easily by connecting a remote charger for a few hours. Check the battery connections are tight and that it has water to the level a bove the plates. If the unit runs well for a while and then goes back to your problem the charger needs looking at. Some batteries get very low and then the chargers will not bring them back up. This needs either a new battery or external charging.
Jul 20, 2014 | Craftsman Garden
Where do i find the spark plug to change it
there is a fat black wire next to the tin valve cover the plug is under the boot on the end of the wire
Jun 30, 2012 | Briggs & Stratton Briggs Stratton...
13 hp tractor keeps draining battery
how old is the battery they only last 2-3 years in a mower but if the battery is a known good battery charge it then remove the neg cable and place a test light between the cable and the neg post if it lights up you have a draw unplug one thing at a time till the light goes out don't forget the charging system itself
May 10, 2012 | Garden
I have an older craftsman GT 18 riding lawnmower that came with a snowblower attachment. Do you know how to attach it?
The snowblower attachment manual is available in the manufacturers' website. If not, go to the Murray website. They manufactured these tractors for Sears. You may find the manual there.
Oct 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Jun 23, 2009 | Craftsman Garden
Lawnmower is spewing white smoke
white smoke means that there is water in the fuel air mixture during combustion. a bluish white smoke means oil is being burned during combustion. take another look and make sure which one it is. since all mowers ive seen are air cooled the only way water can be getting in the fuel air mixture is through the gas cap. check your gas tank and gas can for water. may be best to empty both and start over with fresh fuel
Jun 09, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
718 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
