Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell proheat 2x won't release soap water
Heater working, suction fine also, tubes don't seem to be clogged. Just no water being released through hand tools or floor
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tyu8
Posted on Sep 30, 2010
I can't get the brushes to rotate and the water to spray on the bissel pro heat 2x.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I am having problem with the sprayer to work.. It doesn't seem clugged any suggestions
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 22, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell pro heat 2X has stopped dispensing water from the tank, the suction is working and it seems to be dispensing the detergent, so it is not rinsing or washing with water. I have cheaked to see if...
Apr 19, 2010 | Vacuums
Bissell 9500 ProHeat 2X Clean Shot will not let water put from tank?
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
Apr 19, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer priblem
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
BISSELL PRO HEAT X2 CLEAN SHOT
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Open the door and you will probably find it is clogged with hair, carpet fibre., etc.. Clean this out and you will hopefully have suction again.
Nov 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell won't release soapy water solution
heatman101
hjf
Nov 14, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
816 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
