Question about Rockford Fosgate Punch 301M Car Audio Amplifier
Power light to amp flickers on and off with a voltage of only 8
Without having something to read the voltage can i still find a way to fix my powerless amp?
  • 655 Answers
Hello goup1819,
There are some basic things that you can check without a volt-ohm-milliamp meter (VOM or multimeter), but having a meter really enhances the troubleshooting process.
I'd begin by checking the power and ground. Make sure that you have the appropriate gauge wire and that all of the terminals and connections are tight and solid. Particularly check the ground wire. It should be as short as possible and be connected to BARE METAL on the vehicle chassis or frame. Make sure that there is no primer, paint, undercoating or corrosion impeding the connection. Likewise, the power wire needs a firm connection, preferably using a ring terminal, and be a direct run from the positive battery terminal, through an appropriate fuse, to the amp power terminal, and be as short as possible to minimize voltage drop.
You can also check some of the vehicle wiring. Rusted and corroded connections can reduce the voltage going to your amp. You can loosen the connections and clean them off with a wire brush or sandpaper and then retighten them. Check and clean the connections on both battery cables at both ends, and also the cable coming from the alternator. Do this cleaning with the negative cable disconnected from the battery post.
You can test the amp directly by using a "spare" 12V battery or use the installed vehicle battery by bringing power to the amp using a good set of jumper cables and a couple of short pieces of 8gauge wire. Just be sure to keep exposed portions of the jumper cables away from any metallic surfaces and temporarily covered with plastic or other insulation. If the amp powers up properly with this direct power test, the problem is definitely in the vehicle electrical system or there's too much voltage drop in your amp wiring. If the amp still shows low voltage, then I'd suspect that the amp is defective.
Hope this helps.
Posted on Jun 21, 2009
How do I wire in a amp meter please
amp meters are wired in series in a power circuit
that is to say cut the wire and attach each end of the wire to the terminals of the amp meter
you have to know the amps in the circuit to get an amp meter large enough to read the current or it will burn out
( a 60 amp meter for a 120 amp power wire is not right)
in that case you can get an amp meter that runs a resistance in the back of the unit and as volts and amps are directly related by reading the voltage drop across the resistance the current (amps) can be read
That allows a small amp meter with a high face reading to be attached to a large current wire 10000 amps etc
you can also get amp meters that have a crab claw clip that goes around the power wire and by reading the flux field voltage converts that to an amp reading without touching the wire ( used by electricians to check current draw in electrical motors etc )
Apr 12, 2017 | Cars & Trucks
I replaced my car battery on my malibu 2002 and now I have no power on my radio and nothing showing on its display. I checked the fuse which is on the passenger side. Everyone talking about antitheft but...
Not only check the fuse, use a test lite and check fuse circuit for voltage, hot all the time. The ground wire color for radio is black. Other than checking voltage and ground, I doubt I can help?
If the radio theft is activated, my info says, locked, should show on the radio display. After you figure voltage and ground, if locked shows up on the display, may info says you need a scanner to unlock it.
Feb 05, 2018 | Chevrolet Cars & Trucks
95 gmc safari not getting 12volt to the relay or fuel pump. Is there a fuse or inertia switch some where
Only Fords have a fuel safety shut off switch
You need wiring diagrams & the ability to
use a volt meter & test for battery voltage
& the voltage drops you get at test points
vs: the battery volts your looking for
You can't fix what you don't know
You can't test without a road map to
start your testing (wiring diagrams)
A 1995 is an old vehicle
So I would say there is a 95% chance you have dirt
rust & corrosion somewhere & lost the ground side of some wiring connection
I would as much as it isn't something you want to do,
suspect the problem may be on top of the fuel tank
You can with wiring diagrams, start your testing at the relay
socket & the relay can be tested out of the vehicle
Aug 31, 2013 | Cars & Trucks
Car have no power when put in drive, **** a lot.
No one on the internet or over the phone can diagnose
& resolve any vehicle issues
You need to have the car to road test,talk to owner
& do some testing
You personally can't do much, without wiring diagrams
& diagnostic manuals & charts to follow & learn it's systems
Dec 07, 2012 | Audi A4 Cars & Trucks
Bake oven is not igniting. I had replaced the ignoter last year, Now I tested the igniter and it has low resistance so I went to test if it is getting voltage when the oven os set to bake. I saw something...
you have to read it out with a clamp on amp meter,clamp onto one of the ignitor wires and read it out,flat ignitor should read 3.2 amps,round ignitor is 2.5 amps.is the ignitor glowing or not ?
Jan 23, 2011 | Ovens
My car recently had an issue with charging the battery. We replaced the altenator. That did not fix the problem. Batter was still not getting charged. So we got a new regulator. Still nothing. I...
ALL OF THE FUSES NEED TO BE CHECKED WITH A FUSE TESTER. THERE ARE FUSES UNDER THE HOOD & INSIDE THE VEHICLE. ALSO, WITH THE MOTOR RUNNING AT A HIGH IDLE, PUT A VOLTMETER ON THE BATTERY. IT SHOULD READ BETWEEN 13.80 & 14.90 VOLTS. IF IT READS LOWER THAN 13.0 IT IS NOT CHARGING. IF IT READS TOO LOW MEASURE THE VOLTAGE AT THE ALTERNATOR WITH THE MOTOR RUNNING. IF IT READS TOO HIGH THE ALTERNATOR IS CHARGING BUT THE VOLTAGE IS NOT GETTING TO THE BATTERY. YOU MAY HAVE TO REPLACE THE WIRE BETWEEN THE ALTERNATOR & THE BATTERY.
Jan 18, 2011 | Honda Accord Cars & Trucks
I replaced my thermostat last night without
check for 24 volts ac at R & C terminals at the t-stat. Your transformer will have 4 wires hooked up to it. Two on one side and two on the other. Two of them will read either 120v or 240 v ac depending on whether you have a 120 or 240 v voltage. The other side should read 24 volts. If you are not reading 24 volts, then you have burnt the transformer and will need to replace it. If you are reading 24 volts, check to see if there a low voltage fuse located on the control circuit board or somewhere between the transformer and "R" terminal.
Here's a picture of a typical low voltage transformer found in an A/C system:
If you replace the transformer, add a 5 amp fuse on one of the 24 volt leads......this will save you from having to replace another transformer in the event of future "short" in the low voltage circuit.
Contact me with any questions or concerns.
I hope you find this to be very helpful to you moving forward,
Please leave a rating. :-)f0b3aee.jpg
May 09, 2010 | Heating & Cooling
1998 cadillac catera new batteries die, voltage meter reads low
you want me to pay you for help, and you want me to tell you how I fixed the problem without you paying me! ! ! ! Huh, something doesn't seem right here. How about you pay me to tell you how I fixed the problem!!!
Nov 24, 2008 | 1998 Cadillac Catera
The amp doesn not power on
First off I would double and triple check the connections to make sure everything is making good contact. The first place I would look is the ground. Make sure it has a clean paintless contact to metal. Then use a multimeter and check the voltages on the amp. If you dont have a multimeter borrow one or buy a cheapy one that has digital read out. You can get one for like $5 its a good tool to have.....when your head unit is on go to the amp and put the black lead on the ground and the red on the battery input. It should say about 12 volts and then put the red lead on the remote lead and it also should say 12 volts. If there are voltages there then there is something wrong with your amp and unless you paid more than $800 then it probably isn't worth fixing but if you are interested I could try to find you a place that I could get a quote. If there isn't voltages there then fix your wiring. I hope I could help. Good luck
-Andrew Hawkins
Jul 31, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Rockford Fosgate Punch 301M Car Audio Amplifier Logo
129 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
