www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Code: C2557
Code
C2557
Description
Abnormally low toner density detected Black TCR Sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 5 % or less for a given number of times consecutively.
Remedy
1 Perform image troubleshooting procedure if image density is low. 2 Clean the TCR Sensor window on the underside of the Imaging Unit if dirty 3 M7 operation check PWB-M CNDM3-10 to 13 C-21 4 Reinstall Imaging Unit. 5 Change Imaging Unit /K. 6 Change PWB-M. 7 Change PWB-MFP.
To change language: Press "Utility/Counter" Press number 2 key, then number 1, then number 1 again. This will get you to the language selection without having to read the screen. Once there select your language. If this does not correct the problem, you may have a board or Nav Ram problem and should contact someone for service.
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Magenta Image unit mite be the problem have it replaced if it already was then mite have a bad new one also check the sensor that monitors the toner for the magenta Also pull out the magenta image unit shake side to side to spread out the develop inside the image unit along the entire length of the image unit reseat the image unit.
