Question about Car Audio & Video
1. rcvr was LOADING ...continuously, then, on pwr up, screen flashes then goes blank. Has worked fine for over 2 years. Using home kit, not in car. 2. Checked wall wart/pwr supply and it is 5.0vdc as required. Purchased used xt and have the same problem! 3. Is pwr supply shutting down under load? 4. Is there a front panel reset method? 5. Is there a 'time used/drop dead' programmed into these things?
  • 1 more comment
  • k2qwq Jun 21, 2009
    Rylee,
    My problem is with a Roady xt xm radio receiver - no phone involved and the buttons you mentioned are not on an xt.
    Please try again.
    Doug
    OK - my unit is not an in-dash but there did not seem to be a catagory for this particular xm receiver. Roady xt with home kit.
    Operating from 110vac with a wall wart.
    Again, the used (but supposedly good)unit behave the same way which points to the wall wart.
    Again, on power-up, the screen flashes (nothing shown) then goes black. The original unit worked for 2 years and xm radio customer service says all is OK from their end.
  • k2qwq Jun 22, 2009
    Verified my own trouble shooting.
    Strange English!
    Found another walwart in my junk box and rigged it to the Roady xt plug - works OK.
  • 583 Answers
Its the clear problem of power supply in your unit.the power supply is showing proper in the meter but actually its not holding the load of current and screen is going black.the power supply connections has to be checked first to sort the problem or the another power supply unit is required .many a times the wires gets weak internally.
thanks.keep updated.
Posted on Jun 21, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
You need to perform the master reset procedure which is given below:
With the device powered off, press and hold the 2 soft key buttons (buttons at the top on each side with the dash on them) and then press the power button once and then keep holding the 2 soft key buttons until you get prompt (Black screen with white text). Be sure and hold the two buttons for a second or two after the black screen appears or it will disappear again. Press the Green phone button (send) to start the reset procedure.
After the phone goes through a reset it will prompt you to press confirm to reboot the device and it should be clean at that point. One more suggestion, before you do the reset, take out the sim card. This way you will not lose all your data. When it says it needs to reboot, press "ok", then slip in the sim quick.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
My viewsonic monitor has stopped working. When I boot my machine the start screen flashes and then the monitor goes blank. As the boot process continues, each new page flashes briefly then the screen goes...
Viewsonic LCD?
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 05, 2010 | ViewSonic Computers & Internet
Screen goes blank and standby light keeps flashing red
How to fix ps3 yellow light of death 3. tips first
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then there are 2 options left for you on how to fix your ps3 safe and fast!
Send your playstation 3 back to Sony
You might think that this is an great option, but take a look at some statistics. Most users had to wait at least 4-6 weeks before they had their Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done! Does this still sound as a good option?
Jul 27, 2010 | Sony PlayStation 3 40GB System
Hello iv just gone into facebook loads home page fine but when i want to play a game (any) it goes to load but just keep getting whit screen and saying done at bottom left of screen anyone help???????
Hi!
that always happen when the web browser you are using is not that good in loading facebook site.. And it will be even harder loading facebook games if your browser is not using the latest version of Adobe flash player (a software for viewing animation, video watching and games application that is used for web browsing.
how to speed up facebook and game loading?
My suggestion is you use the latest version of Mozilla Firefox as your browser, it is the best so far for loading facebook account. Download also the latest version of Adobe Flash Player and install it to your computer.
After doing this, you will see the difference, and will enjoy fully the games of facebook.
here's the link for mozilla firefox and adobe flash player.. just click it, and save the file, once finished downloading..start installing
1. Firefox - http://www.mozilla.com/products/download.html?product=firefox-3.6.3&os=win&lang=en-US
2. Flash Player - http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax.exe
Hope this help you... Enjoy facebook.
Much appreciated if you rate this help...thanks..
May 29, 2010 | Facebook Social Network
2-3 years old, acquring signal, not ant-error,
Do you get audio out of the stereo jack? Do you have the proper antenna with TWO leads for TERR and SAT ? It could also be as simple as your antenna alignment not being to the SW, or you could have had a local repeater get shutdown. Also, this radio is several years old (designed in 2001) and could be 'shot' already from heat damage as these get really hot. I would try the radio in the car with a car antenna perched on the roof and see if it works; if it does, then it's your antenna alignment. Good luck my friend and report back please.
Jan 09, 2010 | Kenwood KTC-H2A1 SIRIUS Radio Receiver
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2009 | Apple iPhone 3G
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
Oct 11, 2008 | Dell Dimension 2400 PC Desktop
Screen
if evrything ok in your fone except the screen(LCD). the problem is your LCD maybe its just a lose contact or or the LCd is broken maybe it can help to you ^_^
Sep 27, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Sony Grand Wega KDF-E50A10 showing msg about unauthorized content HDMI
Did you select the output of Cable box to HDMI out? I think it is in the menu setup on most cable boxes. It maybe active but if it isnt, try this.... Hold Menu button down and see if setup menu comes up and then toggle with arrow buttons on front of settop box and try and select HDMI if it is in there. Also make sure settings are on in the T.V. menu as well. Let me know and we will continue. Thank you ...GURU JAY
Jan 30, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
