Question about Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
I have a Saeco Talea Ring Plus espresso maker. The error message I'm getting is "Dispensing failed". I have cleaned the brew group, descaled the machine, and generally fiddled around with the brew group. It grinds beans, pre-brews and then it's as if no water is getting through the circuits. Nothing comes out the spout and the damp grounds are dispensed into the hopper. Water is not leaking and water comes out the steam/water wand without any difficulty. Any suggestions???
Thanks in advance!
  • 3 more comments
  • Molly Bolt Jun 24, 2009
    Thank you! I also decreased the dose and all is well. For future reference where is the screen and is it accessible for cleaning? Once again, thank you very much.
  • Anonymous Mar 15, 2014
    talea ring plus
  • Anonymous Mar 16, 2014
    Talea Ring Plus does not start
  • Anonymous Mar 21, 2014
    cannot dispense coffee. ventilate message stays on
    President:
  • 1,618 Answers
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
  • Ernest R
    Ernest R Jun 25, 2009
    The screen is in the brew unit, if you pull out the unit and turn it around and look at the big red gasket, just below that is the screen and screw.
Saeco talea grinder is starting when you start the machine
this sounds like the machine simply needs a good cleaning due to grounds jamming the switch in place
Sep 05, 2014 | Saeco Talea Ring Plus Espresso Maker with...
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
ok with a machine you have already for a while :
Putt descaling solution in the machine. unplu the machine and open the watere valve. Aftre about 2 days it should have desolved.
BUT>>>>>>>>>> what also can be is that the valve on the bottom of the water tank is not working.
Fill it a little and wiggle the valve until water comes out and than try again.
Priming normally goes.
Water in tank. push water button and open valve.
May 22, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Talea Touch 14-Cup Coffee Maker Logo
2,312 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
