Question about 712T Keyless Entry 2-4but Rem Ob Relays Horne
Horn relay I cannot locate the Horn relay on my car. I keep getting different suggestions for its location, but none of them are correct. Where is it?
  • 78 Answers
Hi need to no full car details
Posted on Jun 20, 2009
Where is the horn fuse for a Kia 1999 Sportage?
The Horn relay is in the relay block behind the driver's knee airbag. You have to unscrew / move the driver's knee airbag to expose the relay block.
May 12, 2017 | Kia Cars & Trucks
Horn does not work on 2001 ford expedition fuse is located under hood good where is the horn relay and what is the colors for the horn maby bad ground at horn under hood or in steering colum when i press...
https://s26.postimg.org/e04ja62e1/horn.jpg
Click on the link.
As you can see, no actual horn relay, but, there is the security module. As far as the security module location, seen two different locations in my database, so I'm not sure of location?
Give me a second, will try to post wiring diagram.
Sep 04, 2017 | 2004 Ford Expedition
Hi. We have a 2000 ford focus se, we changed the horn, fuse is good and relay is good.Changed the horn pad,worked for one day,horn sounds when we locked the car with the key fob.but not with the horn...
can be lots of things.
1: fuses. blown (always 1st)
keep in mind some cars, have 2 horn relays
1 for keyless entry sys.
1 for horn button
if the button fails i can be the button is bad, or the wires from it to the relay is bad,
the wiring is simple (steering wheel with air bags are dangerous and complex)
but alldata.com has the drawings. and even how to fix it.
under AIRBAGS (defeat ) 1st
then under HORN
its all there all the time.
i never assume what is wrong, i do the tests.
i check the signal at the correct relay first , the follow the fail path
to its logical conclusion. i dont guess. and for sure i never put
my BODY near any active air bags, ever. nor should you.
if you need to know the exact location of parts. i can look it up.
its at alldata.com
Oct 20, 2013 | 2003 Ford Focus
Location relay 2007 jeep compass horn
Dealer says it is located under the inner fender plastic of the drivers side. None of the answers here are correct. I have not located it yet as well. However certainly not the steering wheel to say it is suspect, cause you can make it honk using panic button, or when you lock the car with the keyfob, it beeps for 1 second.
There are no relays in the driver side TIPM and there is no fuse indicated in the Owners Manual for the Horn itself. A call to O'Reilly Auto Parts and they told me the horn relay costs about 17 bucks but they could not pull up a picture. Google gives you random images of useless information. I know a Dodge Caliper 2007 is the same basic design but not the same.
Jan 16, 2013 | Cars & Trucks
Horn keep goin off. need to locate horn fuse
What kind of vehicle? It is probably under the hood in that fuse box.
Mar 05, 2011 | Chrysler Sebring Cars & Trucks
Horn not working. When depressing the horn button on the steering wheel, only "clicking" sound is heard near the front passenger side. Checked the fuse and turned out to be unbroken. What's next?...
The clicking you hear is the horn relay working.
I would locate the horn and insure the wiring is intact and the horn has a good solid ground.
Then while someone is pressing the horn button measure the voltage at the wire that attaches to the horn to ground. If you get 12v or more the horn is bad. If you don't get any voltage replace the relay
Jan 23, 2011 | 1995 Jeep Grand Cherokee
Horn wont stop cant locate fuse
The fuse block is located below the dash and mounted to the fire wall. This area is where the brake pedel is located. If you still can't locate the fuse, open the hood and the horn is located behind the grill. Remove the wire from the horn. To fix the problem correctly it's possible that the horn relay is stuck closed which is why the horn blows. A wiring diagram will show the location of the relay. Most relays snap into the holder.
Jan 02, 2011 | 1998 Oldsmobile Eighty Eight
Horn chatters--- suspect the relay 91 S 10 truck. I checked the horn by grounding it and running a wire from positive side to terminal of horn.
The relay is located in the "Convenience Center" as GM calls it, which means its probably not convenient. This is located behind left side if IP panel.
I do not have a relay location number. I would put my finger on the tops of each of the relays and actuate the horn. When you find the right relay it will be clicking right to rhythm to the horn.
You can also unplug the horn and actuate the horn button and listen and feel for the relay. This will allow you to better hear what is happening. Keep in mind this relay may only be malfunctioning under load (with horn in circuit) so you may get a normal click on and off rather than the chatter or stutter you are referring to. Replace the relay anyway.
Jan 22, 2010 | 1991 Chevrolet S-10
712T Keyless Entry 2-4but Rem Ob Relays Horne Logo
90 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
