Question about Dryers
Dryer is running but will not get hot - Dryers
    Brigadier General:
  • 8,619 Answers
Hi!
There are following reasons for dryer running but not hot:
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it because electric heating elements aren't repairable.
Thermal fuse
Thermal fuse is mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
If the above two solutions did not resolve the issue you are facing with then you need to check the wiring which is a common problem for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
Clothes seem to get too hot
The cycling or operating thermostat is often the problem when a dryer runs too hot, but there are also other things that can make it run hot also.
Clothes Dryer getting too hot
heatman101
Aug 13, 2011 | Maytag Dryers
Dryer was running very hot and now there is no heat
heatman101
Aug 08, 2011 | Amana DLE330RAW Electric Dryer
My dryer is running hot but doesn't dry the
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
My dryer runs for about 10-20 minutes then shuts off because it must be overheating. After it cools down I can run it again. Is that an element problem?
heatman101
Aug 01, 2011 | Kenmore Dryers
When the dryer is running top of dryer where controls is hot to the touch
heatman101
Jul 29, 2011 | Hotpoint NVL333EY Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
heatman101
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Dryer runs hot, and clothes are really wrinkled
heatman101
May 07, 2011 | Frigidaire Electric Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
Marvin
Marvin
