Question about Cadet Manufacturing American Standard 2366.100 Cadet Pressure Assisted Flush Toilet
Flushing problem with American Standard toilet model 2474
I have had an intermittant flushing problem with this toilet for the last 4 years. It finally stopped flushing properly 2 days ago. I almost tore the toilet apart checking everything until I was at my last check point and that was the the jet hole in the bottom of the bowl. American Standard advises to use a screw driver to clean it out and do not put your finger in it. I had no screw driver that short so I used my finger and found the hole large enough to put my finger in. I immediately felt something that had been causing my intermittant flushing problem these past 4 years. It took me about 45 minutes to get out a 1 inch white plastic disc that was just bigger than the jet hole so it could never make it thru. It is the same disc that is used to keep the flush valve float at the proper level in the tank. This disc was white and the ones that came with the unit were yellow. I had to use a 3 inch pair of pliers that my wife had for her sewing machine to get ahold of it and pull it out. Conclusion was that this got into the lower half of the toilet at the factory. This may be why I have been reading that so many people are having this flushing problem with this model toilet. Anyway, it is fixed now and running as advertised. Hope this helps somebody else to keep from pulling your hair out.
American Standard 2474016.222 also had the same problem mine had two discs apparently on efrom factory perhaps and one from the floating disc that must have fallen off I used a screw to get them out adn drained as much water as possible then went back and forth adding water a little at a time and then using a tolwel to sponge the water out (no shop vac around) After findign one I then found the other. This post saved me sooo much money adn I have dealt with the intermittant problem for years in this spare bathroom THANK YOU SO MUCH
Posted on Oct 19, 2010
My patent is an over-flow tube for “water-saver” toilets. After being tormented by toilets that leaked and needed at least 2 flushes, I finally came up with an easy fix without taking off the water tank. It’s called NuFlush. I now have it on my website (NuFlush.com) and also on eBay. My house is only 5 years old and all of my over-flow tubes in the water-saver toilets were only 5.25 inches long. I did not have enough water height in my tank to seat the flapper valve, properly, and our water bills were really high. Please look at my web site and see if you think I am on to something. I think that only someone like your self could market this extension tube. I have built 50 thousand of them, locally, and have started selling them in ACE Hardware stores for $6.00. ACE buys them for $3.00. There are 13 sizes of extension-tubes that range from 1.010 inches to 1.3 inches. I would like to make a deal with you.
Thank you. Ron Drake
Posted on Apr 04, 2010
  • 38 Answers
This can happen when toilet is being installed too.And if you use those bluing mints in tank make sure to keep them away from flapper,they can get pushed in to bowl.
goodluck.
Posted on Jul 24, 2009
Which is the best toilet?
American standard cadet III is a nice flushing toilet that is reasonably priced. The tank is smaller than the cimarron. Toto also makes good flushing toilets that would fit your needs, but you will pay more for it too.
Apr 15, 2014 | Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
I recently bought (9 months ago ) an american standard brand model CADET 3 one piece unit and recently 1 month ago , after flushing the toilet the water fills the up the water tank but there is...
theres probably debrie in flush valve, mite also try putting food dye in tank (any color) if it appears in bowl the flapper is seeping water and activating flush valve..
Nov 21, 2010 | American Standard Cadet 3 Right Height...
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
Dec 09, 2009 | American Standard 2002.014 - Champion4...
We just replaced out toilet because we had no flushing power on the old one. After cleaning the vent pipe and using a snake and putting on the new toilet, we still don't have any pressure when flushing...
its got a blocked down pipe lime scale will do this to you, the only way to sort it out is strip it out completly and give it a good clean, if that still failes to flush then its the flushing pump needing looking at,
Oct 25, 2009 | Cadet Manufacturing American Standard...
Toilet keeps flushing
you need to replace the flapper, it's allowing water to seep thru
Jul 09, 2009 | American Standard 2002.014 - Champion4...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Cadet Manufacturing American Standard 2366.100 Cadet Pressure Assisted Flush Toilet Logo
1,656 people viewed this question
Top Cadet Manufacturing Home Experts
john h
Tom Chichester
Are you a Cadet Manufacturing Home Expert? Answer questions, earn points and help others
