Question about Dynasty DGRSC 30 Gas Kitchen Range
Whirlpool gas range - new ignitor is not getting hot
I have a whirlpool gas range - new ignitor is receiving 120volts from the power side and shows 120volts to one terminal at the gas valve. The ignitor is not getting hot?
  • 126 Answers
Do you have 120 between ignitor feeds/wires?if not put a jumper between 2 connections on gas valve,.If ignitor comes on ,bad valve .if not bad tstat/control issue
Posted on Jun 20, 2009
How to check flame sensor
The sensor when cold should allow power through it. If it is open internally it will not allow power to get to the ignitor. If you have a meter it should show continuity or 0 on the meter. If you get OL on the meter or no action on an analog type meter the flame sensor is open or dead internally. One way to check it without a meter is to bypass it by touching the 2 wires together while the dryer is operating. (not recommended for the novice) What it does is allow power to get to the ignitor, when the ignitor gets hot enough it allows the ignitor to shut down. Power however is shifted to the solenoids whenever the ignitor is hot only. So heat from the ignitor hold open one of them coils as long as it is kept hot by fire. If for some reason the fire was not there the ignitor would cool off and the gas would be shut off. Clever ain't it? How about a home video showing the operation in action?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 29, 2013 | Whirlpool LGR3624JQ Gas Dryer
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not heat cooktop works properly
if your oven has a hot surface ignitor it will be visible when looking in the broiler section of your oven if you have an upper and lower burner the bottom of oven will have to be removed to find the ignitor when oven is turned on ignitor should glow a bright red the ignitor works off 120volts if you have the knowledge and testor however a visual inspection if ignitor does not glow and part of the igniter appears white with a smaal crack line in the middle it is probbably broken at that point also if you have testor you will have a continuity reading threw the ignitor
Dec 07, 2009 | Computers & Internet
I have an older whirlpool free-standing gas range and oven and the broiler works but the bake option does not, the oven doesn't get hot, any suggestions?
you may need to replace the bake ignitor. if it is glowing orange and not white, it isn't hot enough to light the bake. hope this helps
Oct 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
OVEN WILL NOT LIGHT IT SAYS IT'S ON BUT WON'T IGNITE OR COME ON
more than likely its a bamke ignitor, one sure way to find out is the range will come on but never get hot and never get above starting temp
remove the bottom panels and you should be able to see the ignitor, turn on the range as normal and visually inspect to see if the ignitor glows
no glow,,,, there you go
call sears repair and tell em you need part number
9758079 ignitor bake
its about a 5 on a 1-10 difficulty ,,,,,unplug the range
Oct 02, 2009 | Whirlpool SF368LEPS Stainless Steel Gas...
Oven burner will not light. Ignitor is orange hot.
When ignitor gets worn it will come on but not get hot enough to open the gas valve. Very rarely the valve fails.
Part number 5303935066
May 20, 2009 | Frigidaire FGF334BG Kitchen Range
Hot point oven will not come on
you have to check voltage at ignitor while thermostat on/if 110 volts you need new ignitor.if no power will trace back to next componet.i think one side would be thermostat other netural?
Jan 04, 2009 | GE EGR3000 Gas Kitchen Range
Oven gas valve wont come on
your valve is bad replace it the ignitor needs to darw a min of 3.5 amps to open the valve if it is drawing the amps then the valve is bad
Jan 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dynasty DGRSC 30 Gas Kitchen Range Logo
243 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Marvin
Marvin
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
