Question about Toshiba Satellite M45-S2692 Notebook
Comp shut down
One night u was just surfing the net then comp just shut off ....screenwent black with no sign or anything.....It was running rather slowbefore it shut down...other than that dont know what went wrong.....nowwhen i put battery charger it sounds like its trying to charge thebattery......but no lights go on (signaling battery ischarging) bells and whistles its as if the comp is dead....what should i do? i do have 2-yr warranty with walmart do u thinkthey could find what went wrong an d fix it?
  • Koobin Apr 22, 2008
    same thing happened to me but i cant even tell its trying to charge bat. I have no warranty and i checked the power supply with a meter and it was fine. thanks in advance for any help. I really need to recover HD asap.
  • 143 Answers
Dont even mess with it just send it in you will void the waranty
Posted on Nov 03, 2007
Screen goes blank after windows corporation logo
perhaps you need to reinstall the operating system,the system files might be corrupted because of power problem,and there's "windows loading files" thing,so the windows cannot go further because it cannot find some files while loading. do you need any help with installing operating system?
Aug 25, 2012 | Toshiba Satellite Pro L300 Notebook
Computer is frozen
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 10, 2010 | HP Pavilion DV6700T Notebook
Was on the net exe box displayed and it autoshut down my pc now when i turn on no icons are displayed only the background pic help!
I don´t know am I understand you question, but I think that is somthing on the net shut down you computer.
It can be hapend if you system isn´t original, or if you pick up some very bad viruses.
In both case the best solution is new system with full format all you hard drive.
That you have icons on the desktop, can be if you go on net, you will be always have the same problem (shut down comp.)
Nov 08, 2009 | Office Equipment & Supplies
The laptop loads up, lets me sign in, then goes blank, no icons
Try booting to the safe mode (F8 at boot) and see if you can log in via the safe mode. If you can't, try booting to your Windows CD, go to recovery console and run CHKDSK /R
If you still can't log in, try running diags see if the hard drive lists a failure.
if no hardware failure found, there and none of those solutions work, then re-installing windows will likely be the final resolution
Oct 06, 2009 | Dell Vostro 1500 Notebook
do a power drain
- shut down the comp, unplug the adaptor and unplug the battery
press and hold the power button without any power connected to the comp
- plug the battery and plug the ac adaptor and turn on the comp
Oct 04, 2009 | HP Compaq nc6220 Notebook
After it as rained all night, I try to start my Saturn SW2 1999 in the morning and the RPM goes up to 3000 and if I put it on drive it will shut off. If I let it run 3min. and shut it off then turn it on...
when u start it up let it run for a second then tap the gas let it idle down then put it in gear. it should run fine then. but its a setup in the staurn comp. its a constant cold start method.
Jul 22, 2009 | Saturn SW2 Cars & Trucks
Sudden shut down for VGN CS16G
there is virus in bios or fan is not working properly.
Jul 16, 2009 | Computers & Internet
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
I can hear background music but no picture on any tv i try
The solder under the GPU has lost Contact. We do offer this repair service. email us
Oct 03, 2008 | Microsoft Xbox 360 Console
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
