Question about Lands Phones
We have a Uniden "Power Max 5.8" cordless telephone. Is it possible to use the handset#2 on the base for #1? The handset#1 is no longer operable as it was dropped into a bucket of water. We'd like to use the #2 phone in a bedroom now but do not wish to have 2 bases taking up space especially since one base is used only to connect the tlephone line. Advise please. Thanks, Nancy Colleran
    Problem Solver:
  • 6 Answers
Both handsets should be compatible with both phones, disconnect the base not connected to the phone line and it should still work.
Posted on Jun 20, 2009
The DECT telephone is linked to our mainline phone - however it does not pick up the dialling tone or the ring tone. The battery is okay, the signal is good, but you cannot speak on the phone. ...
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 09, 2011 | Uniden DECT 6.0 Cordless Telephone...
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
Uniden dect 1580. I have 2 bases and they are both identified as base #1. How do I change one of them to base 2?
I too have a Uniden Dect6 Model 1580-2 with two handsets. The system comes with 1 base (the larger one) and a phone charger (the smaller one with no buttons, just the charger cradle and a led that lights when phone is plugged in).
I was puzzled with your 2 bases affirmation and I checked with my set.
I took handset 1 and pressed the Menu button. I selected HANDSET SETUP. The first option under this heading is Select base, with two choices Auto and Base #1. I tried both choices and each time there was only a base #1, no base #2, thus confirming that in the set there was only one base.
If you have more than two bases, one handset can be registered to more than one base (actually 4 compatible bases). I suspect that you have to register each handset to each base. By doing so, each handset will know that it can connect to two bases and you will be able to select base#1 and base#2.
Jan 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Fell in sink...no longer works
First of all it is possible to buy another phone if you go to uniden.com.
As much as the one that fell in the sink, remove the battery cover and battery, dry inside the phone and battery. Then place all parts in a warm room (NOT on a radiator) and leave for 24 hrs.Then reconnect and see if it works. My fingers are crossed for you.!
Jan 02, 2010 | Uniden DECT 6.0 Cordless Telephone...
My tru9480 handset is saying connecting but won't connect and won't get a dialtone
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Jun 13, 2009 | Uniden TRU9480 Cordless Telephone
Uniden Power Max 5.8 - (TRU8880-2)
please rate this post
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Search inside Uniden DECT 6.0 Cordless Telephone Expansion Handset with Caller ID Knowledgebase the water proof phone base holder jack has yellow tab in bottom and doesn't fit in hole ...is the yellow tab...
I finally realized the ac connections came in 3 sizes ...the first 2 I tried didn't fit the waterproof phone; altho 1 came in the same box.....I feel a little humble
Jul 20, 2008 | Uniden DECT 6.0 Cordless Telephone...
TELEPHONES LOOKING FOR BASE?
Hi Peg,
First get new batteries. do  go to Radio Shack! Take the original with you and go to Best Buy, Circuit City....Office Max, or Staples and be sure they are IDENTICAL .   Voltage and MH (milliamps)
Thanks,
Bob
Oct 19, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
Open Questions:
Lands Phones Logo
100 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
