Question about Nokia 5800 XpressMusic Smartphone
Can't see last dialed numbers
Hi,after i did all the software updates for my nokia 5800 i can't see the last dialed numbers.The green button is not working.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
U need to go to logo in the menu option and u should enable the logo option
Posted on Jun 21, 2009
I forgot my password to unlock that phone how do I unlock it
Hi Yassien, Unfortunately you cannot unlock it as that's the security measure. Your only bet is to wipe and start over...
Before doing this method please be reminded that you should back up all you files first. (search for a desktop software that you can connect to. Since your phone seems to be from asia, maybe this generic connectivity software may suffice.
You connect the phone using a USB cable.
http://microsoft-phone-data-manager.en.softonic.com/
After that, then let`s proceed. Factory settings reset. In standby, dial *#7780# and the phone`s lock/security code (the nokia`s default security code is 12345). This reset restores phone`s original settings. Soft reset. In standby dial *#7370# and the phone`s lock/security code. Warning! Soft/Hard reset deletes ALL your phone`s data! Hard reset (the three key code/reset). Turn off the phone. Press and hold three keys together, the green/talk key, the * key and the number `3`.Then, turn on the phone and don`t let the three keys before you see the nokia hands logo/nokia boot up screen. For 5800 XM or some phone like that. Hard reset need different keys/buttons. The green/talk key, the red key and the camera key/button. The process is the same. You can also upgrade your phone into newly found firmware if there`s any. Install it using Nokia PC Suite and Cable that is compatible with your device and then Presto! You got a bradnew cellphone! Well, most likely. :)
Apr 28, 2016 | Cell Phones
Hi,i have nokia 5800 xpress music unable to view dialed ,received & missed calls. It says no dialed numbers
  • Increase the log duration option.
  • Also check whether the theme is blocking you from viewing the call logs.
Mar 19, 2013 | Nokia XpressMusic 5800
How can i format my nokia 5800 express music mobile phone.. now it has so much of probs.please help me.
  1. Attempt to restore your phone to factory settings by dialing *#7780#
  2. If that does not help, then soft reset your phone by dialing *#7370# and entering your lock code (the default is 12345).
  3. If the above still does not help, the only as a LAST RESORT use the following procedure to hard reset:
  4. GREEN/RED/CAMERA keys pressed all at once while phone is switched on. (This will only work on 5800's that have firmware version 20 and up. )
Jul 03, 2011 | Nokia 5800 XpressMusic Smartphone
I have a Nokia 5800 XpressMusic phone, I am having problems is the delivery of my sms's it goes directly to my outbox. Can anyone assist
Nokia 5800 XpressMusic Soft Reset
Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345).
OR
Nokia 5800 XpressMusic Hard Reset
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination
Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed.
Jun 02, 2010 | Nokia 5800 XpressMusic Smartphone
My Nokia 5800 Xpressmusic has frozen on the "nokia start up screen". What should I do?
hi the only thing to do is to reset the phone to factory setting by pressing the green button the camera button and the on/off button simultaneously
May 21, 2010 | Nokia 5800 XpressMusic Smartphone
How can i fully formated my nokia 5800 express music
The reset will restore all the phone’s settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
For hard reset
Switch off the phone and Press GREEN + RED + CAMERA + ON simultaneously until you see the “Select country
May 20, 2010 | Nokia 5800 XpressMusic Smartphone
Half of the buttons dont work on my phone. how do i fix this?
DIAL *#0000# AND CHECK YOUR SOFTWARE VERSION. IF IT IS OLDER THAN THE VERSION V50.0.005 YOU MUST UPGRADE YOUR PHONE. IN THE OPTIONS MENU PRESS CHECK FOR UPDATES OR UPDATE YOUR SOFTWARE BY USING PC SUITE ON COMPUTER.
May 06, 2010 | Nokia 5800 XpressMusic Smartphone
I recently bought my new phone nokia 5800 music express but the software on the phone is not getting update, when i try to udpate it says updates not avaiable , but i have checked with my friends phone...
Different Nokia series have different update levels. Every nokia 5800 unfortunately can not be updated to the same level of update. Because manifucturer wanted to have some levels according to the selling politics.
Last year I bought two Nokia 5800 smartphones on the same day from the same store. One was for me, other one was for my wife. But these two smartphones unfortunately do not accept the same level of updatel. When I bought them, both have version 20....
Now one is 31... other one is 21.... while everybody around here use the level of 40...version.
So if your smartphone does not accept to be updated then nothing to do except to buy a new one.
Regards.
Dec 07, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 5800 XpressMusic Smartphone Logo
142 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
