Hi Gerti ,
It is very easy , First lift the vehicle through jack or hydraulic lift and drain the engine oil in a pan and arrange a new engine oil filter and oil as it is better to replace( u can use the same if it is not very old). U can drain the oil by removing the drain plug ( keep it for around 1 hour so that oil from the gallerias also drain out).
After 1 hour remove the oil pan by removing all the bolts from engine and replace with the new one.
Top up the engine oil by removing the dip stick and your car must be fine.
Thanks
For more oil and oil pump details check
out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil
Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil
Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil
Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from
valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on
dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to
alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil
from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is
consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message
on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?
http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html
Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
How to replace Oil
Pan on car?
How to replace Oil
How to replace Oil
Pump on car?
Car oil leak?
Car oil leaks from
valve cover gasket?
Oil light blinks on
dashboard?
alternator?
Why car leaks oil
from oil filter?
Why engine is
Maint REQD message
on car dash?
This will help.
Thanks.
