Question about Arris DCT2608
Two tvs off Motorola DCH3416
I want to connect my Motorola DCH3416 cable box to an additional HDTV.
I am currently using the Digital Audio (S/PDIF) and the HDMI outlets on the Motorola box for my main tv.
I know I will need to watch the same channel on each tv, but I want to be able to come off the same box for both tvs.
Thanks
Ken
  • 30 Answers
If you have different input options on your TVs, you could run the second TV with the Y, Pb,Pr component outputs along with the analog audio from the STB. However, remember the STB will only support ONE output video format. So both TV will have to be set to the same video format (720p, 1080i, 480p, etc)
Posted on Jun 21, 2009
Can i connect my motorola dch3416 dvr to my laptop and save programs that i recorded to my hard drive?
Motorola DCH3416 has an USB port to connect to a PC. But you can't copy the files from DVR to laptop, they are encrypted and locked down, even if you opened the box and pulled out the drive you wouldn't be able to get a PC to recognize the format or copy the files off the drive.
(You can not connect data devices without contacting your service provider.
Because the Digital Rights Management (DRM) laws instituted by the entertainment industry prohibit the movement of copyrighted content from one system to another.)
Hope this helps
May 31, 2010 | Motorola Computers & Internet
How to set a clock on a hd dual tuner dvbr dch3416
The clock should set automatically, synchronized with your cable provider's time. You can't change it, as far as I know. OR does it display the channel number and you want it to display the time? If so, go to your onscreen menu (home), choose setup, choose cable box setup, front LED display: current channel ----> current time.
Mar 14, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Would like help with hook up wiring
i can not find the sound driver of my notebook NT-R45 can you help me pls
Jun 03, 2009 | Sabrent SBT-USB51 External Sound System
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Volume trouble with 37LG30
well if you want to get rid of he tv i offer to buy it from you
Habunoki@yahoo.com
Feb 03, 2009 | LG 37LG30 37 in. LCD HDTV
I AM TRYING TO TURN MY JVC TV INTO A MONITOR FORMY LAPTOP BUT I CANT SEEM TO GET THE RIGHT CHANNEL. I KNOW ITS NOTHING TO DO WITH MY LAPTOP SO ITS TO DO WITH THE T.V. I THINK I NEED SOME SORT OF CHANNEL TO...
hi dear
Laptop Multimedia Ports Info
Component Video Out: Connects a TV or HDTV to your notebook so you can view high-quality, high-definition video streaming from the notebook. This three-piece connection (color-coded red, blue, and green) is the best method for sending video from your notebook to an HDTV or anything that receives component video. This connection allows the chrominance (color) and luminance (brightness) portions of a video signal to be processed separately, thus producing higher-quality video than an S-Video connection. S-Video works similarly, but component video improves color accuracy even further by splitting the chrominance signal into two portions.
Composite In/RCA: Connects a gaming console or camcorder to your notebook, for viewing video or playing games on the notebook. Color-coded red, white, and yellow, composite video input uses standard RCA-style jacks to connect your notebook to receive video and audio signals from your TV, VCR, game consoles etc.
TV Tuner/75-Ohm Coaxial: Connects a cable box, TV, or VCR to your notebook, so you can watch and record TV content on the notebook.
Sometimes called an Rf input, a 75-Ohm coaxial cable can carry video and stereo signals simultaneously. RF cable connectors (often called F-type connectors) screw onto the 75-ohm jack, are pushed onto it, or connect via a dongle that vendors usually supply.
S/Pdif/Dolby Ac3 Digital Out: Connects your notebook to speakers or a stereo receiver to play digital audio stored on the notebook. S/PDIF (Sony/Philips Digital Interface) is a standard audio-transfer file format, usually referred to as digital audio. This connection allows the transfer of audio without converting the signal to and from an analog format, which can degrade its quality. If you also have an S/PDIF In port, you can play digital music stored on an MP3 player through your notebook. The headphone jacks found on some notebooks double as S/PDIF Ports.
DVI: Connects a digital projector or LCD panel to your notebook to display in large format either video content or a PowerPoint presentation stored on the notebook. DVI (Digital Visual Interface) is a multipin connection used for passing standard-definition and high-definition digital video signals. It's found on HDTV tuners, a growing number of DVD players, HDTV-ready televisions, and some computer displays. DVI-D is the type of DVI connection found on most home video gear and carries digital-only signals. DVI-I is used with some computer video cards and can pass both digital and analog video signals. Some TVs have DVI-I inputs for greater hookup flexibility. DVI connections transfer video signals in pure digital form, which is especially beneficial if you're using a fixed-pixel display like a plasma, LCD, or DLP TV.
Firewire/ I.Link 400/ 1394: Connects a digital camcorder or external hard drive to transfer (but not display) large files, such as MPEG video, to your notebook. Also known as IEEE 1394, this is an extremely fast (commonly up to 400 megabits per second), two-way digital connection used for plugging in Your DV camera or other peripherals (such as an external hard drive or optical drive) to your notebook. It is used in digital camcorders because it is one of the few connections capable of quickly transferring full-motion video.
S-Video In: Connects a digital camcorder to your notebook to display video stored on the camera on your notebook's screen. Also, if your VCR has an S-Video Out port, you can transfer your VHS tapes to digital format. S-Video inputs use a four-pin jack to receive video signals from camcorders, gaming consoles, TV, or any device that has an S-Video out port. the S in S-Video stands for separate: S-Video connections transmit the chrominance (color) and luminance (brightness) portions of a video signal along different paths, allowing them to be processed separately, though S-Video does not produce as vivid an image as component video. This is a common way to display content from a digital camcorder or any device that has an S-Video Out port. (Firewire also transfers data files from your camcorder to your notebook, but it can't display video in real time on your notebook.)
S-Video Out: Connects a plasma or newer TV to your notebook to display video content streaming from the notebook. The most common way to connect a TV to a notebook, S-Video Out uses a four-pin jack to send signals from your notebook to your TV or anything that accepts S-Video In.
and use Fn+F5 or Fn + F4
to switch your ntbook to tv
oke
Mar 22, 2008 | Computers & Internet
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
No right channel audio when using HDMI connection to HDTV
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Jan 27, 2007 | Arris DCT6200 DTV Receiver
Arris DCT2608 Logo
779 people viewed this question
Top Arris Televison & Video Experts
Marvin
Marvin
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
