Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
When I replace the GXRLQR cartridge, it unscrews & won't stay on.
I had the same problem last time I changed it so I bought a complete filter assy. and replaced the entire assy. which worked by doing that. Now it's doing it again. It seems that the cartidge cannot be replaced by itself. I have not been able to replace a cartridge by itself yet. This eliminates the luxury of just changing the cartridge only. I turn the water off, unscrew the filter cartridge, screw in the new cartridge, turn water on & the water pressure causes the cartidge to unscrew & pop off. The cartridge looks like it has two ramped locks on it to keep it from unscrewing but they apparently aren't working properly. Any suggestions?
  • 126 Answers
You are doing something wrong.It is usually a 30 second repair.Make sure you apply upward pressure as you turn the filter .Should go at least 180' .Water valve not under much pressure ,cant be water causing problem .Hope this helps
Posted on Jun 20, 2009
How to restore lost water pressure after replacing undersink filter?
make sure the filter is going the right way.They have one direction.
Jun 20, 2015 | GE GXRLQR GE SmartWater Inline Filter...
How do I change the water filter on a Frigidaire FRS6R5EMB
If it's the model I'm thinking of, it has a screw in filter cup up in the rear, upper right corner of the fresh foods section. Just twist that weird shaped cup on the bottom counter-clockwise and then pull down on it. It should come out with the filter in it. Then, just take out the filter, put a new one in, and then screw the filter cup back into place.
From a manual of a similar model to yours:
To change filter:
It is not necessary to turn the water supply off to change the filter.
1. Open freezer door and leave open until filter change is
complete.
2. Turn OFF side mounted ice maker by raising wire signal
arm to the UP position. Turn OFF rear mounted ice maker
by pressing ON/OFF power switch to the "O" position.
3. Hold filter cup firmly, and unscrew towards left (Some water
could leak out as you remove cup. This is normaL). Filter
cartridge should come down with cup. If cartridge remains in
housing, puli down gentl_; while twisting filter back and forth.
4. Rinse out cup under running water.
5. The large o-ring that seals the filter system fits in the o-ring
groove inside the cup. Should the o-ring fail out during filter
cartridge replacement, simply place it back in the groove
prior to screwing the cup back in place. If the o-ring becomes
damaged, you wiIIneed to order one from the Flectmtux
Solutions Hottine.
6. Discard old filter cartridge.
7. Remove new filter cartridge from packaging. Place in cup. The
end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench
To Reinstall Cup= Filter cartridge will self-align as cup is
tightened. Be sure cup is completely tightened with
PureSource TM logo facing outward. Do Not Tighten Past Stop.
9. Turn ON side mounted ice maker by lowering wire signal
arm to the DOWN position. Turn ON rear mounted ice
maker by pressing ON/OFF power switch to the 'T' position.
10. Check for Ieaks. Open refrigerator door. Wipe any water droplets
from the filter cup. Fi[Ia glass with water. If there is a leak,
unscrew filter cup, and reinsert the filter cartridge. Check
placement of large O-ring. Reinstall filter cup, making certain it is
tightened complete!_,_
11= To prime filter system and purge air from water line,
continue flushing the system for approximately 3 minutes
to assure that the purest water possible is stored in the
water tank. There win be noticeab[e spurts and sputters
as the system pushes air out through the system and
out the dispenser nozzle,This is normal.
Oct 18, 2014 | Frigidaire Refrigerators
Where is the water filter on frs24wscb?
Good Afternoon Teresa,
I understand you want to know where the water filter is located on your Frigidaire refrigerator, model# FRS24WSCB. The water filter is located in the top back right-hand corner. To change filter follow the instructions below:
1. Set ice maker lever (wire signal arm) to the OFF (up) position.
2. Hold filter cup firmly, and unscrew counter clockwise. (Some water could leak out as you remove cup. This is normal.) Filter cartridge should come down with cup. If cartridge remains in housing, pull down gently, while twisting filter back and forth.
3. Empty cup of any substance.
4. The large o-ring that seals the filter system sets in the o-ring groove down inside the cup. Should the o-ring fall out during filter cartridge replacement, simply place it back in the groove prior to screwing the cup back in place. If the o-ring becomes damaged, you will need to order a new one from the Consumer Assistance Center.
5. Discard old filter cartridge.
6. Remove new filter cartridge from packaging, and install.
7. Place filter cartridge in cup. The end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench To Reinstall Cup. Filter cartridge will self-align as cup is tightened. Be sure cup is completely tightened with PureSource Plus Logo facing outward. Do Not Tighten Past Stop.
9. Set ice maker level on the ON (down) position.
10. Check for leaks. Open refrigerator door. Wipe any water drops from the filter cup. Run a glass of water. If there is a leak, unscrew filter cup, and reinsert the filter cartridge. Check placement of large O-ring. Reinstall filter cup, making certain it is tightened completely.
11. To condition filter system and purge air from water line, run several glasses of water through water dispenser. This will also assure that the purest water possible is stored in water tank.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Refrigerators
Ge smartwater filtration system has slow moving water
You have to prime air out of new filters. Also if you have a reverse osmosis water system, your water pressure may not be sufficient.
You may have to bypass the filter. Most fridges come with a plug that will fit where the filter goes. good luck
Dec 27, 2013 | GE GXRLQR GE SmartWater Inline Filter...
Bike is bottoming out with passenger. Can I just get a heavy duty spring to go around shock or do I need a complete shock assembly?
You can get a stiffer spring and it'll make a difference. But the shock won't be made to absorb the forces correctly so it might feel a little strange but it'll still work.
Nov 10, 2013 | 2002 Yamaha V Star 1100 Classic
After replacing the cartridge, the water flow is extremely poor. After calling GE, I was told I may have a bad filter. Hope not at the price per filter they charge. Is there any other solution? Is it...
The GE GXRLQR is the correct *replacement* filter for the following "Smartwater" single stage filtration and exterior refrigerator icemaker systems:
  • GE GXRLQ
  • GE GX1S50F
  • GE GQ1S50F
This filter is rated for only 750 gallons / 6 months of use (typical fridge with ice maker & water service). Most home faucets will deliver about 6 gallons / minute which roughly translates to about 2 hours of running water.
The GE FQSLF works with the following for the following Dual Stage Under Sink filtration systems:
  • GE GQSL55F
  • GE GXSL55F
Because there are 2 filters, they will last nearly 2x as long as the GE GXRLQR. and would likely be better suited to serving a faucet which will pass much more water than a fridge ice maker & chilled water dispenser would.
The real question is: Which GE filtration SYSTEM (not filters) do you have?
Sep 09, 2013 | GE GXRLQR GE SmartWater Inline Filter...
Just bought a 2004 mitsubishi diamante with 113,000 miles on it. owner said he hasn't done much if any maintenance on it. what all should I have replaced?
i would have everything checked, the most important one would be the timing belt, this all depends on the engine in this car, with 113,000 miles the timing belt would be the first thing if it has one. the next thing would be an oil change and ****** fluid flush and the filter if its automatic, if standard shift then just the oil because this ****** has no filter. iwould tune it up and have the cabin filter changed, check tires and rotate them and an alignment, have the brakes checked and adjusted if needed, have the shocks and struts checked and the suspension checked,the coolant flushed and brake fluid and power ssteering fluid checked and flushed if needed. the car would and should be checked over completly, this is a good car but maintenance should be done, this will help the life of the car and also you just bought the car, you would like it to last. there are some people that never do anything and car lasts a while but when thing start to go it costs so much because of the lack of upkeep. hope this helps.good day.
Aug 28, 2011 | 2004 Mitsubishi Diamante
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
