Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis won't agitate
When Atlantis reaches agitate stage it will shut down & you can smell a little smoke & wining noise. Braker sometimes shutts off.
Thanks for your help.
    Sergeant:
  • 212 Answers
Possible bad control board.
Posted on Jun 20, 2009
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Washer will not agitate. Hums & you can smell
make /model? A have a car it makes a noise ,do you know what i mean?
Jun 20, 2009 | Washing Machines
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Whinning noise
if your unit sounds like a jet plane, your tub seal and bearing must be changed. You would need tohave a service company do it. There are special tools rewuired that cost upwards of 125.00( just for the spanner wrench) the labor ranges from 110-145.00
Feb 28, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6451 Waterfill keeps filling
hi todd it looks to me that the problem with the water level control or the small level control hose hard water &lint can sometimes clogg this hoe up remove hose from switch and blow into it hard if its clogged you will not be able to blow clean it and try if it does not work after its clean replace water level switch thanks the appliance doc
Aug 09, 2008 | Maytag Atlantis MAV6451 Top Load Washer
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer - MAV6200AWW will fill and spin, but wont agitate. Also lost the bolt going down into the agitator. Anyone know what size it would be?
bolt has 1/2inch head but dont know the thread size is an orderable part 3 to 5 dollors, may not agitate since agitator not on shft to turn
Apr 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
285 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
