Question about Iomega REV 35GB/90GB Disks - PC (4 Pack) Media
When I plug my usb cable into the laptop a bubble tells me my device is not recognised. I cannot see my Iomega listed on my programs at all, have followed some procedures from the iomega website but nothing has worked so far. The Rev seems to be working fine in itself, i.e. power etc but I've had this problem many times before but this time its just not fixing.
    Novelist:
  • 133 Answers
Dear Geraldine78,
Please follow these and let me know if it works...
Connect the USB device to the USB port on your computer and switch on the USB device.. you will see the balloon and it would say device is not installed properly etc .. as you mentioned... Now
Right click on "My computer" --> Properties --> Hardware tab --> Device manager button .. click on + sign next to the "Universal Serial Bus Controllers" do you see any Red "X" or "!" marks?
Right click and un-install the devices with Red X or "!" marks.
Then disconnect the USB device and then reconnect it back to the computer and this time the computer should Re-recognize and then reinstall the device and this time it should work fine.
Hope that helps. Please let me know in case you still have any issues.
Regards,
Srinivas
Posted on Jun 21, 2009
My iomega is not showing up on my laptop?
The best USB ports to use are usually the rear ones.sometimes the bios keeps account of the number of connections and then refuses to recognise.if this is the case then you could try going into bios and switching off USB restart and switch it back on to clear the count. Or yes a different USB cable as these can sometimes create read errors.
Dec 08, 2014 | Iomega Computers & Internet
My iomega hard drive doesnt appear under my computer, it appears in dev. mgr but cannot assign a letter. Windows makes a sound to recognise its there, its says usb recognised and ready to go. just cant...
Iomega portable hard drives connect to your computer through a USB port. When you connect the Iomega hard drive to your computer, it should pop up as an icon in your My Computer folder. If you can't find the icon in your My Computer folder then you probably need to update the driver for the device. Updating this driver is not very hard and can be done automatically from the Windows Device Manager.
Plug your Iomega hard drive into one of your computer's USB port. Click the "Start" button and go to the "Run" field. Type "Devmgmt.msc" into the Run box and press the "Enter" key. Go down to the bottom of the device manager to the "Universal Serial Bus Controller." Click on the little + (plus) sign to expand it. Look for an entry with a yellow exclamation point and click on it. Click the "Install the software automatically (Recommended)" button and then click the "Next" button. Click the "Finish" button when the installation has finished. Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon. Double click the icon to gain access to the external hard drive. Hope it helps.
Jan 22, 2013 | Computers & Internet
Hard drive keeps beeping and not recognised by the computer
Hi check on the device manger id the hard drive is being received by the computer. If it is listed then re-install the driver for it.
If it is not listed on device manger , try a different cable, try a different USB port. Try it in another computer or xbox/ps3 to see if it can be read by them
Also...
Re-install it into another caddy to make sure it not the caddy USB port damaged.
If the hard drive is making a loud noise, the hard drive may be damaged. It may also be the hard drive controller damaged.
May 07, 2011 | Iomega (33600) 160 GB USB 2.0 Hard Drive
My iomega external hard drive is not being recognised in 'My Computer' but is in the device manager. Software updated. Not sure what to try next to use it?
Hi, Thanks for using fixya.
1. With the device connected to the usb port Right click on My Computer choose
manage. On the left side make sure storage is expanded double click disk
management on the left upper side see if Iomega is listed.
2. If it is on the lower part find your Iomega right click on it choose change
drive letter and paths. Click on change, you will see a drop down arrow click
that choose the first available letter, Now click on change. Open My Computer see
if it is now listed. If it is you are done.
3. With the device connected to the usb port reboot your computer when it comes
back,open My Computer see if it is now listed.
Terry
Feb 13, 2011 | Iomega 33089 250 GB Hard Drive
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
I have got a 500gb iomega hdd. I have got it plugged in to my laptop but my laptop will not reconise it. It has a blue power light flashing on the front. I have also tried it on the home desk top and its...
I had the same problem with my external hdd. I had installed Paragon disk management suite 2009. I ran the program with my hdd plugged in and after sometime(15 minutes) i found my hdd was recognised and working fine. Try it. How it worked for me have no idea but it somehow worked.
Dec 30, 2008 | Iomega (33654) Limited Edition 500 GB USB...
Iomega 640GB hard drive not recognised
on your computer, under device manager, uninstall all USB devices, upon completion right click the top of the tree, click scan for new devices. this will reinstall the usb devices. then plug in your ext hard drive
Jan 06, 2008 | Computers & Internet
Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Nov 24, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Iomega external 100mb zip drive
Check out this site: http://www.iomega.com/europe/support/english/documents/11382e.html The pictures that have red arrows show where the cable that should connect to your coputer should go. Yours might be this one: http://www.iomega.com/support/images/iom_sup_zip_100_usb_new_rear.gif
Mar 13, 2007 | Iomega Zip 100MB (31714) External ZIP...
Electronics - Others Logo
60 people viewed this question
Top Iomega Electronics - Others Experts
Marvin
Marvin
Are you an Iomega Electronics - Other Expert? Answer questions, earn points and help others
