Question about HP Office Equipment & Supplies
Out of paper is on on the computer but there is paper in the printer
  • 72 Answers
Turn off your printer and your computer. Unplug both units. Plug them back in. Turn each one on and let your.. computer reboot. See if is resets. If you still have that issuse ..In your computer go to start...control panel...printers...then print a test page...If neither one of these steps solves your problem then you made need to have HP come out for service.
Thank You
Posted on Jun 20, 2009
Communications error between Windows 8.1 computer and Artisan 835 scanner
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Source : EPSON support
Feb 13, 2014 | Epson Artisan 835 Wireless All-in-One...
Tip
Getting a Paper Jam error
Follow the instructions below in an attempt to resolve the issue you are experiencing.
1) Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
2) With the printer off, check for any obstructions such as torn paper or foreign objects.
3) Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Still getting the same error ? Go for Warranty or Service.
Else,
4) Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
5) Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
6) Try to feed paper manually (using the paper feed button).
Else,
7) Before re-connecting the printer to the computer, uninstall the printer driver and restart the computer.
8) Re-install the printer driver.
on Aug 29, 2008 | Epson Stylus C88 InkJet Photo Printer
My HP PSC 1610 paper feed is malfunctioning. When something is sent to printer the message states Out of Paper but there is paper. The rollers don't engage the paper.
Shut down your computer. Pull the plug from the printer to the computer.Wait two minutes. Start the computer and re insert the printer cables. It should recycle and work. f not re-post question.
Jan 07, 2013 | Office Equipment & Supplies
Universal paper size lexmark
Please check the paper size settings on the Printing Preferences option of the printer. To access this on your computer, to go Start > Devices and Printers (Printers folder) > right click the printer icon and then choose Printing Preferences. Set the Paper Size to the desired paper size. Please also make sure the paper guides on the printer is selected to the correct paper size.
Dec 15, 2012 | Lexmark E260dn Laser Printer
My printer looks fine but my computer says " out of paper"
the way the computer will say that the printer is out of paper, is because the printer is telling the computer it is out of paper.
the way the printer thinks it is out of paper, is because the small detector that detects if paper is in the tray is telling the printer that there is no paper in the tray.
make sure that the paper is placed properly in the tray, and that the detector is working.
you can fool the detector by either placing weights onto the tray to imitate paper, or by place objects into the tray near the detector. (be warned, these could possibly lead to damaging your printer if done without being careful)
Mar 28, 2011 | OKI MICROLINE 590 Matrix Printer
It doesn't load paper,when paper was load in a tray,the paper was loaded in jam and also gone in bango.
Welcome to FixYa.
If the printer don't load paper, please follow the following steps.
1. Check the printer make sure no scraps of paper are stuck inside the printer.
2. To check remove the door at the back of the printer.
3. If you paper try to pulled the paper jam.
4. Double check again if there is scraps of paper.
5. Then put back the door of printer.
6. Then, Disconnect the USB cable from the printer.
7. Disconnect the USB cable from the computer.
8. Leave the cable unplugged for 5-6 seconds.
9. Reconnect the cable to the printer and computer. Ensure the printer is connected directly to the computer through a USB cable or power USB hub.
10. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Mar 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Out of paper displays on computer when paper has been reloaded
Usually when you run out of paper the driver changes its status to "paused" just right click the printer and select "resume"
Mar 24, 2010 | Office Equipment & Supplies
Hp laserjet 1200 paper jam
Please Follow the instructions in an attempt to resolve the issue you are facing:
  • Turn off the printer and remove all paper from the paper tray & disconnect it from the computer.
  • With the printer off, check for any obstructions such as torn paper or foreign objects.
  • Turn on the printer (still disconnected from the computer) and check the lights / lcd screen.
Else,
  • Place 20-30 sheets of paper in the printer, ensuring none of the paper is torn or creased.
  • Make sure that the paper is flush with the far right edge of paper tray, move the left edge paper guide over so that it touches the left side of the paper.
  • Try to feed paper manually (using the paper feed button).
If you still get the error let me know for further troubleshooting,
Dont vote till you find it is Helpful or FixYa.
Thanks,
Scott
Nov 14, 2008 | HP LaserJet 1200n Printer
HP psc 1300 printer
I had to turn off my computer, unplug the printer power cord and computer cord. I restarted the computer and pluged in both cords to the printer and it worked.
Oct 07, 2008 | Office Equipment & Supplies
16 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
