Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
When washer goes into spin cycle it doesn't always spin all the water out.Sometimes you have to do it the second time.
    Sergeant:
  • 212 Answers
Restricted water pump. replace water pump/drain pump
Posted on Jun 20, 2009
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a Samsung front load washer #WF220ANW/XAA This problem I am telling you does not happen with every load, but is happening more frequently as time goes on. My washer does not complete the spin...
i am having the same issue but most of the times it is when i wash a load on hot/cold so i am wandering if the water is to hot maybe i dont know but i wish someone knew
Jun 07, 2011 | Samsung WF209ANW 40 cu. ft. Front Load...
The washer goes through the entire cycle and then just before it should be finished....it signals ND - sounds as if it is stopping then unlocks. Only problem is....there is still water in the basin....it...
ND stands for No Drain. This can be cause by 2 things, first being the rotor on the drain pump is broken or falling off. Second, there could be a piece of clothing partially clogging the pump so it works sometimes but not always.
Dec 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
